Linux users: What logging program do you use?
Discussion in 'Logbooks & Logging Programs' started by K4NYA, Apr 24, 2012.
  1. K4NYA
    K4NYA Ham Member QRZ Page
    Recently made the switch from XP to Ubuntu and need to find a decent logging program. I've test driven xlog & klog, but wasn't really impressed with either. Got HRD to install via wine, but I can't get the logging program to launch. Any other I should look into? Should preferably be a to export to LOTW.
  2. BX2ABT
    BX2ABT Ham Member QRZ Page
    Try CQRlog. Excellent piece of software, integrates well with fldigi. Does export/import LoTW and eQSL and is under constant development/improvement. The only gripe I have with it are the key bindings, but that is because I hate using a mouse. Good luck.
    Hans
  3. VA7GP
    VA7GP Ham Member QRZ Page
    While it's not much help to you, I have been OK with xlog. Maybe that is a result of using it for so long, when there were no alternatives. Like Hans above, I've looked at CQRlog, but it wouldn't install on my 64-bit Gentoo machine (required some 32-bit libraries which weren't in the Gentoo repositories). I liked the appearance of CQRlog, though.
    For some digital-mode contests, I have just used the logging-capability which is built into fldigi - however, this really isn't a good general solution for CW, SSB, etc.
    All-in-all, I think I would echo Hans' suggestion to take a look at CQRlog and see what you think.
    HTH,
    -Gord
  4. BX2ABT
    @Gord: you're right, Fldigi also has logging capabilities. If you have rig control set up this would be better for contesting than CQRlog, which lacks serial number/exchange support. Fldigi also exports cabrillo, even though you have to edit the output before sending it in.
  5. W0BTU
    W0BTU Ham Member QRZ Page
    So is CQRLOG and XLOG all there is for Linux?
    I have used CQRlog for some time. It's a very nice piece of work, but I don't like way the drop-down "Frequency:" list feature works at all! Maybe I'm missing something obvious, but it appears that we cannot customize it, and there's no 60 meter support. (I simply HATE having to type in the 60M freqs all the time.)
    I just posted a suggestion on the cqrlog.com forum. We'll see what happens.
    I've tried some Windows logging sofware under WINE, but none of them worked right.
    EDIT: Please reply to me directly, as I am unable to subscribe to this thread due to a bug on qrz.com. This post only intermittenty appears in my browser and I may never see your reply. TIA
  6. N0NB
    N0NB Subscriber QRZ Page
    With rig control set up in CQRlog, I never have to bother with the Frequency box. Mike, make certain that 5 MHz is checked in CQRlog's Preferences|Bands dialog. I don't bother with 60m so I don't have it checked.
    Off the top of my head, there is also Klog, dbLog, TWlog, and probably more in various states of development and features.
  7. W0BTU
    The issue I mentioned with the QRZ database seems to be solved. No need to reply directly as I requested above. Now to more important matters...
    Nate, checking 5 MHz (or any other band) in CQRlog's Preferences|Bands dialog does nothing. All the bands there Except 5 MHZ display in the drop-down "Frequency:" list regardless of what is checked or unchecked.
    What could be wrong, and how do we solve this? I've looked through the config files and see nothing about bands or frequencies. Maybe the main config file is corrupted? I have uninstalled and reinstalled CQRlog but nothing changed.
    Enabling rig control is probably good advice. The last time I thought about it was when I had my IC-751A. Maybe it's easier to to with the rig I use now, an IC-765. But I'd like to figure out what is wrong before I try that!
    EDIT: could someone please send me their ~/.config/cqrlog.cfg file ? TIA! :)
  8. RO2F
    RO2F Ham Member QRZ Page
  9. K7GQ
    K7GQ Subscriber QRZ Page
    Another alternative is jLog from jLog.org. Support is a little light but it does a decent job.
  10. N0NB
    Mike, looking through ~/.config/carlog/cqrlog.cfg I don't find anything regarding the frequency drop-down. I can confirm what you're seeing as I have CQRlog 1.4.1 installed and even after enabling 5 MHz in the Bands dialog, it does not display 5 MHz in the drop-down menu. Even restarting the program the drop-down does not show 5 MHz. This is a bug that should be reported to the CQRlog Bugs forum.
    Also, I'd advise against sharing the .cfg file as personal data is stored in it.
