learning how to sold SMD
Discussion in 'Homebrew and Kit Projects' started by KC6DSE, Apr 19, 2012.
  1. KC6DSE
    KC6DSE Ham Member QRZ Page
    How would you go about learning how to solder surface mount kits? I have this kit from KD1JV, but I'm scared I will scorch the pcb since I'm not well practiced. Any suggestions? I have a Haako iron meant for this type of work. Not sure what type of tip I should use etc.
  2. KF5FEI
    KF5FEI Ham Member QRZ Page
    SMD work is more about having a steady hand and being able to place the part accurately and apply the solder sparingly. I actually solder some pretty small parts with a fairly large tip -- although some folks do better with a long, tiny, pointy tip. Here is a good tutorial video.
    http://store.curiousinventor.com/guides/Surface_Mount_Soldering/101/
  3. AF6LJ
  4. KD0CAC
    KD0CAC Ham Member QRZ Page
    Also keep an eye out for free stuff at ham fests , for practice , so no cost while learning .
    And who knows , you may fix a dead item and be able to sell , or give away .
    Watch out , you may get hooked , bring home a lot of dead gear , and never shop for new again .
    Unless you do well , start making money to pay for the hobby :)
    Do not believe when you hear , that there is no free lunch , you could have your cake / rig and eat / operate it too .
  5. KA9JLM
    KA9JLM Premium Subscriber QRZ Page
    The key is to clean components and use plenty of good quality Flux.
    The solder will flow to your connections and the flux will prevent solder bridges.
    Practice makes perfect. Do not give up.
  6. KF5FEI
    Worth noting the flux they use for surface mount is not the same as the rosin flux you use for regular soldering. You can buy a flux pen (like a paint marker, but with flux instead of paint) and it will make things a bit easier, especially on the really small stuff.
  7. WA7PRC
    WA7PRC Premium Subscriber QRZ Page
    I've been at it a few decades (literally). I've hand-soldered a few hundred thousand SMT components. More than a few of those have been quite a challenge. I agree with most of the advice presented. Aside from choosing suitable soldering "weapons", it takes a bit of practice. I suggest you practice on something that won't matter if you destroy it. THEN you can confidently solder things that do matter.
  8. AB9LZ
    AB9LZ Ham Member QRZ Page
    Solder bridges are usually the biggest problem, be sure to use your continuity tester to check for unxepected shorts after you install each component. Along with a good pair of tweezers, a really fine point awl is handy to have around to pick at potential problem area's.
    73 m/4
  9. N5CEY
    N5CEY Ham Member QRZ Page
    If you plan on doing a lot of smt work, it would be worth your while to get a hot air gun (specifically meant for smt), and solder PASTE. makes the job infinitely easier - the solder just flows to the joints when it melts. We did a couple hundred quad 100 pin flat pack uP's that way with no problems - but as other folks have said, it takes practice.
  10. NA7U
    NA7U Ham Member QRZ Page
    Yeah, the problem with practicing is that you need both a part and a PCB that matches. Perhaps you could find some non-working board with SMD parts on it and remove them with solder wick, then re-solder them just to get a feel for it. The Hakko is a very good iron, I'd suggest about 300-350C for the heat setting. Use either a small chisel tip or better yet I think Hakko has a chisel tip with a concave end that will hold a small blog of solder well. There are a couple of really good SMD soldering videos linked on my blog (below) in the third post down.
