Kenwood TS-850S SSB Filter
Discussion in 'Ham Radio Discussions' started by SP9O, Dec 3, 2012.
  1. SP9O
    SP9O Ham Member QRZ Page
    Hello fellow
    I have a Kenwood TS-850S
    It can be assumed large filter ssb
    FILTER YG-455S1 2400 Hz SSB Filter [455 kHz IF]
    I greet
  2. W0UZR
    W0UZR Ham Member QRZ Page
    What do you want to know about it? There's one of those in my 850 too.
  3. WA7PRC
    WA7PRC Premium Subscriber QRZ Page
    The TS850S comes with the YK88S-1 filter installed. The only optional filters shown in the user manual are:
    [table="class: grid, align: left"]
    [tr]
    [td]PN[/td]
    [td]DESCRIPTION[/td]
    [/tr]
    [tr]
    [td]YG-455C1[/td]
    [td]CW Filter 500 Hz, 455 kHz IF[/td]
    [/tr]
    [tr]
    [td]YG-455CN1[/td]
    [td]CW Filter 250 Hz, 455 kHz IF[/td]
    [/tr]
    [tr]
    [td]YK-88C1[/td]
    [td]CW Filter 500 Hz, 8.83 MHz IF[/td]
    [/tr]
    [tr]
    [td]YK-88CN1[/td]
    [td]CW Filter 270 Hz, 8.83 MHz IF[/td]
    [/tr]
    [tr]
    [td]YK-88SN1[/td]
    [td]SSB Filter 1.8 kHz, 8.83 MHz IF[/td]
    [/tr]
    [/table]
    FWIW, the InRad filters have steeper skirts and IIRC, greater ultimate attenuation outside of the passband.
  4. SP9O
    OK THANK YOU.
    FILTER YG-455S1
    Connection to the TS-850S
    WILL fit
    ALL OK PIN ALL OK
  5. WB2WIK
    Yes the YG-455S-1 will fit the TS-850S and just plug in.
  6. WA7PRC
    It's not listed in any documentation I have for my TS850. However, with the YK-88S1 filter, it would result in steeper skirts and more rejection of signals that are outside the passband. I'd still just use a single filter from InRad.
    DL2AU created a nifty Kenwood filter vs rig chart: http://www.dl2au.de/html/kenwood_filter.html. Since my German is good enough to only get my face slapped, I used Google Translate to read the notes.
  7. WB2WIK
    The YG will work and will fit, it's just not as good a filter. The YG filter is the one that came with the 850's little brother, the TS-450S.
  8. VA6AW
    VA6AW Ham Member QRZ Page
    I have an old TS430S that no longer works. Thinking of selling or trading the YK88c and YK88S filters for something that will work in my TS140S. Would like a narrower and cleaner CW filter. Does inrad have something that I could install without too much trouble.
  9. WA7PRC
    That's why I wouldn't bother, and use an InRad filter instead.
    You have four InRad filters from which to choose: 500/400/250/125 Hz bandwidth. I use a Kenwood 250 Hz BW filter in my TS850. It works FB with the slow tuning rate. Because of leak-through on strong signals, I wish it was an InRad filter.
  10. VA6AW
    Tnx for the info Bryan. The link you provided gives me some idea as what I'm looking to do here.
    I did hear that changing the filters on the 140's could improve the overall receiver front end noise level which is very high here. Or its just the radio design. Not sure as I just started to work with this rig.
