Kenwood TS-2000 Control program
Discussion in 'Rig Control, Propagation, Cluster, & Other Softwar' started by AB0HX, Nov 4, 2010.
  1. AB0HX
    AB0HX Ham Member QRZ Page
    Have a TS-2000 on order and should arrive today. :D:D:D
    I use software on my mobile and handhelds to program memories and love it.
    On the TS-2000 is the software worthwhile?
    I prefer to adjust common things by handleing the radio so just volume, frequency etc on a computer does not appeal to me.
    With that in mind does the software provide any features that are appealing?
    Thanks in Advance.
  2. KA1MDA
    KA1MDA Ham Member QRZ Page
    There are 2 different software packages available for the TS-2000. If you just want to program and/or backup memories, that software is a free download at Kenwood's web site. Look for MCP-2000.
    For remote rig control, Kenwood sells a software package called ARCP-2000. A friend of mine has it, and I wasn't very impressed with it. The interface is kind of kludgy, and most of the features can be implemented for free using something like HRD.
    The only thing the ARCP-2000 software does that is unique is allow the user to construct, save, and load various types of IF filter profiles for the DSP. However, the filter profiles depicted in the software often vary drastically from what you end up actually getting! So unless you verify the resulting filter profile (using something like Spectrum Lab) it's of very limited value.
    I would suggest downloading MCP-2000 first. If you find you still need to remotely access the rig's controls, try downloading HRD.
    Tom, KA1MDA
    www.ka1mda.org
  3. AB0HX
    Thanks,
    Can you get the cable anywhere without buying the entire software package?
  4. KI6USW
    KI6USW Ham Member QRZ Page
    I run the ARCP-2000 software - if that is what you are referring to.
    If you want to try it out, there are 'cracked versions' (software with unlocking code with it) on the internet.
    http://gigabitwarez.com/download/Arcp 2000.html
    Bought the USB cable off of eBay - don't even bother with the cables that come from China. They are the wrong ones (my personal experience) and they take forever to get here and to return for credit. Wasted a whole month on that project.
    http://cgi.ebay.com/6-5-USB-CAT-cab...ltDomain_2&hash=item2a0b4db5d4#ht_1852wt_1057
    As far as the software itself, It works quite nice and most of it is fairly intuitive. There is help on some private Ham websites that can give you loads of useful info for the parts that are less than intuitive.
    http://www.camradio.net/TS2Ktech.html
    There is also a DSP modifier program by N3GX available for free to change TX audio curves on the fly to your own tastes and uses.
    Xlnt!
  5. AB0HX
    Thank you
    Thats a big help
  6. K0EHT
    K0EHT Ham Member QRZ Page
    I have the ACRP-2000 radio control program i bought a few years ago when i bought my TS-2000 and the program worked well with windows XP, It sure don't like windows Vista and been having problems trying to install it on my computer with Windows Vists... Just thought i would let you know about that problem I'm having with it...
    Ron (K0EHT)
  7. K2DSL
    K2DSL Platinum Subscriber Platinum Subscriber QRZ Page
    Congrats on getting a TS-2000. It's a fine rig. For rig (aka cat) control, it's s standard serial cable. If you don't have a serial port, most (though not all) USB to Serial adapters could work. The rig control is the simplest of serial interfaces so most do work.
    As for software from Kenwood, the ARCP program they sell is ok. I personally wouldn't suggest getting it though, at least at first. Programs like Ham Radio Deluxe (HRD) and others are free and from what I recall when I briefly used ARCP, these programs do at least what ARCP does. With programs like HRD and the others, you'll also getting logging software, digital mode software, etc all integrated so they will know the band/mode frequency. None would prevent you from using the knobs on the radio and all provide frequency, band, mode, control from the keyboard/mouse at a minimum.
    Try the free programs first would be my suggestion and good luck with the new rig!
    K2DSL - David
  8. KD0JOF
    KD0JOF XML Subscriber QRZ Page
    I just picked up a TS-2000 a few weeks ago and love it so far. Having trouble with 6m and the ant. :( but I'll get that sorted out.
    I'm using HRD v5 on Windows 7 with only one little problem displaying the secondary freq but it controls the radio great and I still can control everything from the front panel.
    For quickly adding channels to memory I use the MCP-2000 application from Kenwood. It's a little clunky compaired to the version for the D710 but it's fine for what it does.
    If you are using a USB to serial adaptor I would try to find one that doesn't use the Prolific control chip. It seems to have problems with windows 7 and I keep losing the COM port until after a reboot. The one I'm using now is some generic one I picked up at HRO and it works great.
