Kenwood TM-V7A
Discussion in 'Ham Radio Gear For Sale' started by WA4VRV, Feb 15, 2013.
  1. WA4VRV
    WA4VRV Ham Member QRZ Page
    Cleaning out the shack and have 3 of the Kenwood TM-V7A's. So, selling one of them. The radio is in excellent condition - no display problems and full power on both 2m and 70 cm. MARS/CAP Modification has been performed on this radio - VHF TX 136.995 - 173.995, RX 118-174; UHF TX 410-469.995, RX 300-470. Non-Smoker. Complete with original packaging, manual, mic, power cord, and mounting bracket. I am asking $250.00 shipped to the lower 48. Guaranteed not to be D.O.A. Shipping will be extra anywhere else. I accept PayPal. I am an honest ham - check me out on Ham-To-Ham. Best to contact me at my email address - wa4vrv@arrl.net.
    Here is detailed information from the Kenwood site:
    FM Mobile Transceiver TM-V7A/E
    Kenwood's TM-V7A/E FM dual-band (2 m/70 cm) transceiver is like no other: the easy-to-operate control panel with its cool-blue reversible LCD -- offering both positive and negative display modes -- marks a bold departure in ergonomic design. And there's a lot more inside -- like the "four-in-one" programmable memory, DTSS and pager functions, 280 memory channels, plus the ability to receive two frequencies on the same band. Outside and in, the TM-V7A/E is setting the pace for tomorrow's mobile communications.
    Features at a glance:
    Dual-mode reversible LCD
    "Four-in-one" programmable memory
    Dual receive on same band (f2)
    Up to 280 multi-function memory channels
    Memory Name function
    Multi-scan functions
    Visual scan function
    DTSS
    Built-in CTCSS encoder/decoder
    Auto simplex checker
    Advanced Intercept Point
    6-pin mini DIN connector for 1200/9600 bps packet
    Quick-release detachable front panel kit (option)
    TM-V7A/E in detail:
    A world first: the cool-blue LCD panel -- capable of displaying dot-matrix characters -- can be switched between positive and negative display modes to ensure optimum visibility in all conditions. The control panel is large (51.5 x 105 mm) and features four multifunction keys -- with key function display -- for improved operating ease.
    The TM-V7A/E has a multiple "personality" to suit different conditions. Its programmable memory can store four entire operating profiles, ready for instant recall at the push of a button. Each profile includes such settings as positive/negative display mode, dimmer level, frequency range, and memory mode.
    In addition to simultaneous receive on VHF and UHF bands, the TM-V7A/E can receive two frequencies on the same band. Monoband use is also possible.
    There's capacity as well as versatility: up to 280 memory channels for storing important data -- transmit and receive frequencies (independently), frequency step, tone frequency, etc. (180 channels when using Memory Name function.)
    For greater convenience, you can choose to identify each channel with up to 7 alphanumeric characters. In this mode, the number of memory channels available is 180.
    Visual scan with pause
    By automatically checking above and below the frequency currently in use, and graphing the results on the LCD (147 channels max.), this new feature is convenient for searching out open channels.
    Full band and programme band scans, memory scan with memory channel lock-out, MHz scan and call scan are all available. For each band there are TO (time-operated) and CO (carrier-operated) scan stop modes.
    DTSS selective calling with page function
    Built-in DTSS (Dual-Tone Squelch System) allows DTMF access: the squelch is opened only when a specific 3-digit code has been received. The page function alerts you to incoming calls and opens the squelch if the receiver has been programmed to accept a DTMF tone group. And even during normal reception (squelch open), the TM-V7A/E can be on the alert for a predetermined code.
    The CTCSS (Continuous Tone Coded Squelch System) encoder/decoder enables operation of the 38 EIA-standard CTCSS subtone frequencies.
    ASC will automatically check whether it is possible to switch from a repeater to simplex communications.
    You can choose either high sensitivity for simplex/weak-signal work, or a high intercept point -- using Kenwood's own AIP circuitry -- to minimize intermod or adjacent channel interference.
    The front panel features a connector for hooking up to a TNC, enabling either standard 1200 bps or 9600 bps high-speed packet communications.
    To enhance security, simply remove the compact front panel whenever the car is left unattended. If the optional quick-release kit is used, the panel can be mounted virtually anywhere since the microphone cable connects directly to the main unit.
    Guide function
    There's no need to carry the manual with you -- the friendly guide function displays simply operating instructions at the touch of a button.
    Jay, WA4VRV
    wa4vrv@arrl.net
  2. WA4VRV
    Thanks to those who replied. This radio is sold
    Jay, WA4VRV
  3. QRZ
    Important Rules
    Have you read our Swapmeet Safety Rules?
    This forum enforces a set of buying/selling safety rules for the benefit of all users. Make sure that you're familiar with the rules before posting or replying in this area. Our moderators review every post in this forum and will flag or delete those that do not conform.
