Kenwood TL 922 help needed
Discussion in 'Amateur Radio Amplifiers' started by WD8BWW, May 22, 2017.
  1. W1QJ
    W1QJ Ham Member QRZ Page
    I believe I calculated the resistance of the meter to be 500 ohms.
  2. WD8BWW
    WD8BWW XML Subscriber QRZ Page
    I received the meter Saturday and got back to the amp today. I installed it. It is from W1QJ above very very nice OM. Before i buttoned it all up a ran voltage check 0-1 vdc across the 1 ohm resistor terminals. Tracked perfectly. Old meter with the same test was dead so this will clear the no IP reading.
    W9GB, KD2ACO and W1QJ like this.
  3. KD2ACO
    Yeah, he's like that...
    :p
    W1QJ likes this.
  4. W1QJ
    Sure glad it all worked out OK for you. Good Luck.
    W9GB likes this.
  5. KD2ACO
    oops, hit wrong button...
  6. WD8BWW
    thanks for all the help. I'm tied up today but hope to build and fire up the amp, exciter, watt meter and load in the next day or 2. and I will let everyone know the final outcome. I repair a lot of radios but few big amps. When a 1kw amp's current meter is pegging I look for thoughts before I proceed. There is a local repair market for amps but I will not work on them for CB'ers just Hams "with call signs". Funny story: About a year ago I had a local guy call me said he heard I repaired radios and ask about fixing his SB-220. I asked if he was a ham he said quickly.. YES! I asked what's your call sign and are you good on QRZ? He said he could not remember it. You can't make these things up.
  7. WD8BWW
    Amp works great !
    final tally of issues.
    3-500Z filament would not light. purchased a new pair of tubes from RF Parts.
    replaced 1 ohm resistor (open), 1.5 k resistor (brunt), and IP meter (shorted)
    also replaced the 5.1 v zener as a precaution
    Thanks all.
    KD2ACO and KA9JLM like this.
  8. WB2WIK
    All you have to do now is polish it so it shines!:)
    And maybe pray for better propagation.:p
  9. WD8BWW
    The 922 is a beautiful Radio! Looks even better now that it is working.
  10. W9GB
    Don't throw out the old meter. I'll pay postage to keep it out of landfill.
ad: hrd-2
