Kenwood MCP-4A no response from transceiver
Discussion in 'General Technical Questions and Answers' started by KL4RB, Nov 12, 2017.
  1. KL4RB
    KL4RB Ham Member QRZ Page
    Just got a new MacBook Pro that I am trying to connect to my TH-D72. I am using VMware Fusion to run a virtual machine running Windows 10. Windows will see a thumb drive plugged in but whenever I try to read the Transceiver I get an error "No response from transceiver, ensure connection and com port status are correct." I have installed the latest virtual com driver (6.7.5) from Silicon Labs. Any suggestions?
  2. NM7G
    NM7G Ham Member QRZ Page
    The manual's troubleshooting chart (on page 50) for a TH-D72 suggests 3 actions for your error ("MCP-4A communications error" as I interpret your symptom). First guess is the HT's USB port wasn't activated (made live) when you turned ON the TH-D72. As suggestion 3 in the manual's list says, power the HT OFF, then ON again. If that doesn't reset the USB port, try suggestion 2 in the chart and close the VMware Fusion. Does the MacBook Pro now recognize the HT's USB port. I'm Mac ignorant, but this seems like a basic USB initialization issue to me.
  3. KL4RB
    Thank you for your help. Another forum member was familiar with this. I had to go into the virtual machine to change the com port from usb 3 to usb 2 High solved the problem!
  4. NM7G
    Good news! Glad it worked out for you.
ad: portazero-1
