K4DPK VFO Stabilizer
Discussion in 'Radio Circuits, Repair & Performance' started by DV1UBY, Aug 14, 2011.
  1. DV1UBY
    DV1UBY Ham Member QRZ Page
    Hi guys,
    Any thoughts about K4DPK's VFO Stabilizer? I have my Yaesu FT-707 here and it is more often sent to the technician. Anyone here knows where t obtain K4DPK's VFO Stabilizer? I'm from Manila, PHL.
    Also, I tried to check the net and can't find further info about K4DPK's VFO Stabilizer.
    Thanks. :)
  2. KB4QAA
  3. K0CRX
    K0CRX Ham Member QRZ Page
    Alex,
    You might try Cumbria in England. Here's a link http://www.cumbriadesigns.co.uk/x-lock.htm.
    I have an ongoing project using their X Lock with a Heathkit HG-10. I have experimented enough to know that the X Lock is working fine. The current problem is that the added varicap pulls the oscillator tank too far to compensate with a normal alignment. I plan to experiment with different varicaps, but, the bottom line is the X Lock works fine in stabilizing the VFO.
  4. DV1UBY
    Is there anyone can help me find the K4DPK's VFO Stabilizer for my Yaesu FT-707? Any contacts with K4DPK? Until now he's not answering my email. Please help thanks :D
  5. DV1UBY
    Hi K0CRX,
    Is it (the X Lock) good for my Yaesu FT-707? Does it really fix the drifting issue? Or just a replacement for the IC of the VFO (just like the Japanese produced MSM9520RS Replacement Module)? :D
  6. K0CRX
    Alex,
    The X-Lock is a 'huff and puff' circuit (I think that's the correct terminology) that will provide a varying DC output as the input frequency changes (drifts). That DC output, then, biases a varactor, which, when connected to the oscillator tank, provides a corrective capacitance to the tank, thus, bringing the oscillator back on freq. I only understand the function from a high level and can not explain how the detailed circuitry works.
    I do know that my own experimentation using an X-Lock with a Heathkit HG-10 showed very effective freq stability correction. I could monitor the oscillator freq with a freq counter and, when it changed by as little a one cycle, the X-Lock would bring it back. The problem I encountered, and have not yet solved, is that the introduction of the varactor into the oscillator tank upset the oscillator L/C ratio to the point where mere recalibration would not bring it back to the original frequency range. The X-Lock folks recommend using an LED as the varactor. I have only experimented with one LED. I'm hoping that I can find another LED or a real varactor with a capacitance value that does not upset the oscillator tank.
    Sadly, that project has been back-burnered and is in a box on the shelf. Hopefully, I'll get back to it this winter. I operate mostly vintage (vacuum tube) radios and want to put some very vintage SSB stuff on the air and don't want to be wandering up and down the band!! :eek:
    As to your FT-707, I'm not familiar with that radio, but, if the oscillator is of conventional design with an L/C tank, I would think the X-Lock would be a good candidate.
    BTW, the X-Lock folks are friendly and helpful, too!
  7. KO6WB
    For the X Lock you might want to try a 1N914 diode instead of the LED. It has smaller excurtions in capacitance verses voltage and it just might cure your problem.
    Hope that helps
    Gary
  8. K0CRX
    Thanks, Gary. I appreciate the tip!!
