Is there an equivalent to the Linux 'halt' command in Windows?
Discussion in 'Computers, Hardware, and Operating Systems' started by AB2T, May 4, 2012.
ad: K3QNTad-1
  1. AB2T
    AB2T Ham Member QRZ Page
    Just as the subject line says. Can I use the command line to shutdown the computer without using the graphical interface?
    73, Jordan
  2. AF6LJ
    Yes you can
    just bring up the command prompt and type shutdown
    You should get the list of command line arguments...
    The way the command behaves in XP is a little different than in Seven however the same functionality is retained.
    I've used the shutdown command in my computer that records TV shows to shut off the computer after a program had been recorded.
  3. KT1F
    KT1F Ham Member QRZ Page
  4. AF6LJ
  5. W5RKL
    W5RKL Ham Member QRZ Page
    Shutdown, when issued in Windows 7, will save the state of all running applications then shut the machine down. Powering the machine back up will return the machine, including any/all applications that were running, excluding
    any external website applications, to the same state before the shutdown command was issued.If a web browser was logged into a website, that log in sessions will be terminated
    and the operator will have to log back into the website once the machine is back up. I tested this with my 64 bit Windows 7 machine and that's how it functions in Windows 7.
    I don't see the "PsShutdown" command listed nor does Windows 7 recognize that as a valid command.
    73s
    Mike
    W5RKL
  6. KD4MOJ
    KD4MOJ Database Subscriber QRZ Page
    Command is:
    shutdown -h now
    Oops... you meant for windows... i need to read more carefully!
    ...DOUG
    KD4MOJ
  7. AF6LJ
    That also. :)
  8. KA5LQJ
    KA5LQJ Ham Member QRZ Page
    I thought the shut down command for Windows was a "16 pound adjustment tool" and to
    "Press ANY Key", LOL! :p
    Don/KA5LQJ
  9. AF6LJ
    You are confused that is the Mac shutdown tool. :D
  10. KY5U
    KY5U Subscriber QRZ Page
    The trick with Windows machines is to keep them from shutting down, not shutting them down.
