ad: w5yi
Is a Sincore Mighty Mite IV tube tester a decent tester?
Discussion in '"Boat Anchor" & Classic Equipment' started by KA5ROW, Dec 3, 2012.
  1. KA5ROW
    KA5ROW Premium Subscriber QRZ Page
    Is a Sencore Mighty Mite IV tube tester a decent tester?:
    Or should I try to get something from the 70’s to the 80’s? The Mighty Mite VII was there last one made. And even Heathkit had one until 1990.
    I know it is not a conductance tester which is more desirable, but it is in excellent condition. I will use it in testing tubes in old ham radios I plan in refurbishing from the 60’s.
  2. WD8KNI
    WD8KNI Ham Member QRZ Page
    Very good tester.. will get the job done, have one sitting on the bench.. there is an internal as I remember 12AX7 that when weak will kill your readings. I would check that one every few years, other than that if you have the tube book, you are good to go.. Fred
  3. AD8T
    AD8T Subscriber QRZ Page
    I have one of them that was given to me by a TV tech friend who retired. I use it often. So far it has tested every boatanchor tube I've run across. Yes, there have been a few that tested good, but were marginal in-circuit. Perhaps that's due to not being a conductance tester, as you say. I wish I hadn't given away the other tester I had...it was good to be able to test a tube in 2 different testers. I foolishly thought I was done with boatanchors and gave away an attic full of tubes and both testers. Lucky for me, one of the recipients wasn't interested in testing tubes, so I got the Sencore back. No doubt there are some very old tubes it won't test, but I don't do the real antique stuff like BC radios from the 20's and 30's.
  4. W5JO
    W5JO Ham Member QRZ Page
    The Mity Mite is guaranteed to sell tubes. It is an emission tester and almost worthless, find a mutual conductance tester then check the tubes that pass in circuit to be certain.
  5. N9DSJ
    N9DSJ Ham Member QRZ Page
    Like the "Little Gem" fuse tester?
  6. KA5ROW
    You said I should get the Mutual Conductance tube tester, so would that include a Dynamic Conductance. I see there is some difference even between those two.
