Is a "Full Wave" dipole a good idea or not?
Discussion in 'Antennas, Feedlines, Towers & Rotors' started by KC0MS, Oct 20, 2008.
  1. KC0MS
    KC0MS Ham Member QRZ Page
    I read all about half-wave dipoles, but what about a FULL-wave dipole?
    Are there any pro's or con's to putting one of those up if space permits? Any advantage over a half-wave? If I get the green light on this, is the same freg-div-into-468 formula what I would use for dimensions?
    If you're serious:
    1. No of course the formula would be 936/f for a "full wavelength" dipole.
    2. No, the reason people don't use these is because they're very difficult to match: Impossible to use coax altogether; you can use open wire balance line to match a full-wave dipole but it will still be a 5 or 10:1 VSWR...it just won't matter much because the line loss will still be reasonably low. Still, the risk of arching stuff is much higher with a voltage-fed antenna (like a full-wavelength dipole), and there's about nothing to gain overall.
    A better idea is the "double extended Zepp" which is fairly commonly used and about 0.64 wavelengths per leg, or 1.28 wavelengths overall. Its formula is 1198/f and it's a better choice than a full-wavelength doublet.
    WB2WIK/6
  3. W2VW
    W2VW Ham Member QRZ Page
    A full wave dipole will show some gain in the broadside if it is installed high enough.
    A full wave dipole by definition is resonant. It cannot be fed directly with coax though. Lots of people substitute the term resonant for any antenna load that has a low SWR when fed with a hunk of 50 ohm coax. Good quality balanced line feed with a balanced output antenna "tuner" is a common way to have success.
    Google: pair of half waves in phase.
  4. WZ0O
    WZ0O Ham Member QRZ Page
    Check the last Bill Oar book on antennas. AES has it its $19.95. I built the off center fed full wave for 17M and like it. Has a off center figure 8 pattern that runs the same direction as the antenna is strung. 4 lobes. My antenna runs north and south. T he lobes run 380 to 340, 20 to 80, 11o to 170 and 200 to 260. Major nulls at 90, 180, 270 and 360. Hope this helps if you need more about it pm me.
    Brad
    WZ0O
  5. KC0MS
    I was serious in asking the question alright, but now after reading the responses, I see why no one does it.
    Gotta ask, ya know...it's the only way to ever find out....
    Besides wasting the time it would take to put one up and then find out the hard way it won't tune.
    Thanks
  6. K3WRV
    K3WRV Guest
    I actually use something like that - about 550 Feet long, fed in the center with 450 Ohm ladder lind and fed thru a Johnson Matchbox(tm). On 40 meters and up, it's great. Ok on 160 and 80. I've also fed it with TV foam twinlead and an MFJ 941 tuner.
    In theory, it shows a lot of lobes and tends to be directional off the ends., but you can develop some gain Mine runs NE>SW and pretty much covers the world, but is weak towards South America. The lobes haven't been much of a problem. On 80, a 1/2 wave dipole beats it for the most part, but neither is very high - 30-50 feet.
    Wire antennas are easy and cheap to make, and if you don't like it, recycle the wire into something else and try again.
    But as WIK has pointed out, you'll see some pretty strange impedences (I've never tried to measure them), but if you can match them, go for it.
    A half wave dipole provides a good match for 70 Ohm Coax, which is one reason it's popular. And it has a pretty easy to understand radiation pattern (like an infinity or a donunut). But there's nothing magic about it. A very old "all band" antenna is a half wave dipole for the lowest band, fed with open wire, so an 80- meter dipole run on 10 will five the same idea. Try it, you MIGHT like it. Else try something else.
    de Bob
  7. WZ0O
    The OCF will tune to about 1.6 to 1 and mine works much better than the 1/2 wave it replaced. Went together in about an hr. and is fed with RG8. I did use a current balun at the antenna to cut down on feed line trouble.
    Brad
  8. KA4DPO
    KA4DPO Premium Subscriber QRZ Page
    A half wave dipole is doable but requires a quarter wave matching section (tuning stub) to match to coax. Think about a J pole antenna, same thing. The biggest problem you run into at HF is that the matching section is usually only good over a narrow frequency range and adjustment of the stub can be a royal pain. Even then, you would still want to use open wire line or ladder line as a feeder.
    As WIK pointed out there are easier ways to get gain, and a good match with a wire antenna than a full wave dipole. I just didn't want you to think it couldn't be done. It can, but not as easily as some other antenna configurations.
    MM0HVU likes this.
  9. WB2WIK
    ::That was a typo! I'm sure you meant "a full wave dipole....":p
    Anyway, "everything works," it's just a matter of how well. If you have a terrific antenna but can't transfer power into it because it's hugely mismatched, then it's not so great.
    A narrowband matching network can always be built to transfer power from a source to a load even if the natural mismatch is terrible....but then you have a narrowband matching network, which works at one frequency and not anywhere else. This is why most hams don't bother -- however it's a pretty acceptable solution for non-hams in the commercial/broadcast/aerospace/etc industries where a single-frequency match is just fine.
    WB2WIK/6
  10. KC4RAN
    KC4RAN Ham Member QRZ Page
    A fullwave loop, on the other hand, is one of those antennas that many inexperienced hams dismiss as boring, but don't realize the potential they hold, even as multibanders...
ad: SteppIR-1
