ad: AlphaRF-1
Idea for variable capacitor
Discussion in 'Homebrew and Kit Projects' started by KF5JAK, Mar 15, 2012.
  1. KF5JAK
    KF5JAK Ham Member QRZ Page
    Not wanting to order a variable capacitor for a DIY tuner, I had an idea of use a 6+ pole rotary switch wired starting with a direct connection, bypassing the capacitor, then a 100pf cap, 200pf on the 3rd pole, etc. Maxing at 500pf. Now, I know this won't be as precise as a "real" air variable capacitor, but, I would think it's better than nothing. Just wanted to get some opinions on it from some people a bit more experienced than myself. Thanks!
    Will only work if the tuner's inductor is continuously variable, like a roller inductor.
    Otherwise I think this is a waste of time.
  3. KF5JAK
    Why a roller inductor, why not tapped?
  4. K7JEM
    K7JEM Ham Member QRZ Page
    The idea is that something has to be nearly continuously variable in order to properly tune. If your caps are fixed, then the inductor needs to be variable. If the inductor is tapped, then the caps need to be variable, or have at least a good number of positions.
    You could probably put in toggle switches with cap values of 5, 10, 20, 40, 80, 160, and 320pF. That would allow you to pick any capacitance from 5 to 635pF in 5pF steps, but it would use 7 switches. That would probably be small enough steps to work with a switched tapped inductor.
    Joe
  5. AB9LZ
    AB9LZ Ham Member QRZ Page
    A lot of autotuners work this way, using switches (relays) to swap values around until it finds something close to a match, the problem is that a computer can manage that kind of switching complexity pretty easily, humans not so much...
    Spring for a variable cap, it's worth it.
    73 m/4
  6. K7JEM
    Exactly. But if he wanted to do it, it would be possible. Perhaps if he had a few spots to tune up on, and the antenna wasn't changing much, he could write down the switch settings and make it work for him.
    In order to tune up on a random frequency, it might take a while to go through all the possibilities manually. A computer controlling relays can do that in a few seconds.
    Variable capacitors are not all that expensive, and for a manual tuner would be a better choice.
    Joe
  7. K8ERV
    K8ERV Ham Member QRZ Page
    Another possibility would be to use a small variable cap to fill in the voids in the switched system.
    TOM K8ERV Montrose Colo
  8. WB2WIK
    Very true and some commercial amplifiers did that. My old Johnson Thunderbolt amp actually did that, although the variable cap wasn't exactly "small," since it had to handle a kW at 200 Ohms load. So, it was big, but not a lot of range. The range was all by fixed, switched caps (also fairly large transmitting micas). But the idea certainly works.
  9. W9GB
  10. K5UOS
    K5UOS Ham Member QRZ Page
    My opinion is buy a variable capacitor. New and used capacitors are easy to find.
    You did not say what tuner you will be building. A QRP vs QRO and/or long wire vs some other type could have different requirements.
