ad: wmr-1
ICOM IC-775 DSP Fans Not Working
Discussion in 'Radio Circuits, Repair & Performance' started by K7QHU, Sep 23, 2019.
Tags:
  1. K7QHU
    K7QHU Ham Member QRZ Page
    Hello Group!
    The fans on my IC-775 DSP are not working. The maintenance manual for the radio does not mention the fans and on the schematic I can not determine if there is a common part (relay, thermal control, etc.) that controls the fans on/off operation. Since it is unlikely that all three fans (power supply, PA unit and tuner unit) would fail at once, I am thinking there may be a common element to the failure.
    Has anyone else seen this problem and resolved it?
    Thanks in advance for any suggestions/solutions.
    Steve K7QHU
  2. KA9JLM
    I do not know for that radio exactly.
    ICOM is good about having fuses to protect the radio. Many are surface mount.
    Does everything else work normally ? A dead regulator may be something to test for.
    Good Luck.
  3. K7QHU
    Thanks for your reply. Everything else on the radio is working great. I will re-check the schematic for fuse locations.
    K7QHU
  4. KA9JLM
    Have you done a radio reset ?
    The CPU may control the fans.
  5. K7QHU
    I had not thought of doing a reset. I just tried it and then let the radio run for a while... The cooling fans still remain off. In the service manual for the radio, the block diagram shows a transistor "Q20" marked as "Fan Control". However I cannot locate this on the schematic :(. Thanks for the reset suggestion.
  6. NU4Y
    NU4Y Ham Member QRZ Page
    I have not worked on a 775 and I don't know where Q20 is. BUT
    The PA fan is controlled by Q5,Q7, Q8 and Q9 on the PA PCB.
    They way I see it anytime your in TX, Q8 turns on, turning Q5 on and Fan MF1 should run. Then again what do I know.
    KA9JLM likes this.
  7. KA9JLM
    Do you have a web link to the schematic you are using ?
    I would like to have a Look See.
    Good Luck.
  8. M6AGL
    M6AGL Ham Member QRZ Page
    Check you have good earth connections for all 3 before delving deeper. They all need an earth and that is common to all 3.
