ad: UR5CDXcom-1
Icom IC-740 Optional Filters?
Discussion in 'General Technical Questions and Answers' started by KB1SFA, May 2, 2012.
  1. KB1SFA
    KB1SFA Ham Member QRZ Page
    Does anyone out there happen to recall what optional filters were available for the IC-740? Currently, I am running one of these as my primary radio (mostly SSB) and would lime to add a fiilter or two to help clean up my recieve a little bit. I looked around ebay and found an FL-30 ssb filter, but was not sure if that is a stock filter already included or an optional filter? If someone recalls what the available filters were that would be a great help. Thanks and 73s. - Greg KB1SFA
    Easier to just use "new" INRAD filters for the IC-740; there are a variety available, and most are better than the original ones used by Icom.
    A listing of available filters for the IC-740 is here: http://www.inrad.net/home.php?cat=76
  3. KB1SFA
    Thanks I will definitely look into INRAD's filters. I am a little surprised that someone is still making filters for a radio that old...
  4. WB2WIK
    There's a lot of them, and IC-745s, and IC-751s and other models that use the same filter type. It's INRAD's specialty.
  5. K7MH
    K7MH XML Subscriber QRZ Page
    From http://www.universal-radio.com/catalog/hamhf/740.html;
    EX-45 Filter 500 Hz CW/RTTY (9 MHz IF).
    EX-54 Filter 270 Hz CW narrow (9 MHz IF).
    EX-52 Filter 500 Hz CW-narrow (455 kHz IF).
    EX-53 Filter 250 Hz CW-narrow (455 kHz IF).
    All the other options for the IC-740 are listed there as well.
    There is a ceramic filter in the 455 IF. A worthwhile inexpensive mod was to replace it with the mechanical filter (if I remember correctly) from an IC-730 which would drop right in the 740.
    Hmmm...
    The manual on page 28 shows some different filters than those listed above.
    http://www.rigpix.com/icom/ic740_manual.pdf
    Inrad would be the way to go. Myself, I am not real crazy over SSB filters.
ad: EasyWay-1
