ICOM IC 707 HF Transceiver
Discussion in 'Radio Circuits, Repair & Performance' started by VU2LOL, Aug 29, 2012.
  1. VU2LOL
    VU2LOL Ham Member QRZ Page
    I have Icom IC 707 HF Transceiver which looks like
    It was not in use for quite a long time. Now, when I brought the equipment into use again, I am facing some problem, which seems to be stubborn.
    When I switch on the rig, and the squelch is turned on, no signals are received; but there is a continous loud tone coming out through speaker.
    What I predict is dat the rig is unable to receive the RF signals and some other internal signal is being generated which is heard through speaker.
    I want some help on it, if someone could suggest me a way to bring it to operation again..
    DE VU2LOL
    73s
  2. KE3WD
    KE3WD Ham Member QRZ Page
    In storage for "long time" -- always, always, the first thing to do is open 'er up and use Dexit or equivalent cleaner/lube spray on all controls, switches, to include any rotary switch contacts (BUT NEVER use on any AC power switches!!) and also hand tighten all circuit board hold down screws you can find, as often they are also ground points.
    Corrosion of switch, control and relay contacts, grounds, etc. can cause these kind of symptoms and it is imperative to do the above before attempting anything else as just that can often restore proper operation and in many cases even return circuits to calibration, or close to it. Corrosion and dry contacts can insert some pretty high resistances into circuits. Cleanliness, next to Godliness...
  3. WB2WIK
    I don't recall much about that rig (I've heard of it, and that's about all) but from your description it sounds like it's actually creating a CW "sidetone," like it's switched to the CW mode and believes it is being keyed.
    Does it do this in "all" modes?
  4. VU2LOL
    Tnx KE3WD..
    This sounds helpful.
    n I will definitely try it out.
    Tnx agn..
    73s
  5. VU2LOL
    WB2WIK..
    Yes the rig is producing the same tone in all modes.
    and yes the fact told by you might be the possible case.
  6. N4EYZ
    N4EYZ Ham Member QRZ Page
    uh oh, hope it's had a 50 ohm load on it, or it just "thinks" it's being keyed. (no rf out)
