ICOM 7600 FIRMWARE PROBLEM
Discussion in 'Rig Control, Propagation, Cluster, & Other Softwar' started by G7FIF, Dec 9, 2010.
  1. G7FIF
    G7FIF Ham Member QRZ Page
    I AM HAVING A PROBLEM UPDATING MY IC 7600 TO VERSION 1.03.
    IS THERE ANY SETTINGS IN SET MODE THAT I HAVE TO MAKE TO ENABLE THE RIG TO ALLOW A FIRMWARE UPDATE? ANY HELP WOULD BE APPRECIATED. MANY THANKS.
  2. K3TD
    K3TD Ham Member QRZ Page
    re: ic-7600 firware update
    Hi Gerald, I have an IC-7700 and understand the upgrade method is similar for both radios. I have upgraded my firmware twice by following the documented steps in order in the manual. Where in the process are you getting stuck?
  3. G7FIF
    Hi Tad, Thanks for your responce. I have followed the steps in the order of the manual,
    Everything is fine from paragraph 1 to 8 on page 164 of the manual. The problem is when I go into paragraph 9, Nothing is displayed in the blue window, nothing appears in the blue window when I press F2 or F3.many thanks for your help. Gerry.
  4. K3TD
    re: IC-7600 firmware update
    Gerald, are you trying to do the upgrade using a usb thumb drive? If the 7600 is like the 7700, you first must have the radio format the thumb drive, then download the firmware from your pc onto the thumb drive, then upload the firmware to the rig.
  5. G7FIF
    IC 7600 FIRMWARE UPDATE
    Hi Tad, Thanks for your responce. yes, I am using a USB Flash drive, and carried out the exact proceedure that you suggested and as per 7600 manual many times. I am begining to think that there is a problem with the 7600,what do you think Tad ? Have you any other suggestions ? It has got me stumped.
    Many Thanks, Gerry.
  6. K4PP
    K4PP Ham Member QRZ Page
    Do you have the 1.03 dat file in the IC-7600 folder on the thumb drive? It has to be in that folder or the radio won't see it.
    K4PP
  7. VE3PP
    VE3PP XML Subscriber QRZ Page
    Gary by any chance do you happen to have a digital interface connected to the radio?
    I wanted to upgrade the PEP software on my FT-950. When I booted up the software update software and started it that software could not find the Com Port.
    I checked the Com Port setting within HRD, it showed Com Port 1. I tried again, on Com port 1 and no go.
    So I got thinking, the SignaLink USB is plugged into the computer and radio. So I took the 6 pin data cable off the back of the rig and sure enough the software found Com Port 1 and installed itself no problems.
    Just a thought.
    Rick
ad: cq2k-1
