IC 7300 + SDRPlay?
Discussion in 'Software Defined Radio (SDR)' started by N6MST, Jul 9, 2019.
  1. VA3VF
    VA3VF Ham Member QRZ Page
    Then this, but even more expensive:
    https://www.dxengineering.com/parts/dxe-rtr-2
  2. VA3VF
    The loop goes to the RSP. The RSP goes to the PTRX-7300 input. TX uses whatever antenna is on the 7300 antenna port. The RX audio is available on the computer running the RSP, as well as CAT control of the RSP tracking the 7300.
  3. K4MJA
    K4MJA XML Subscriber QRZ Page
    from the manual I referenced:
    Basically, you connect SDRPay to an antenna through T/R limiting switch and use PC to view the spectrum/waterfall when in receive. Any free SDR software will work. Is that what you are trying to achieve? If so, it is done many times over. I have all the pieces but never got around actually testing it...when I want a nice waterfall on my PC, I just use Flex which has extra antenna ports.
