IC-7300 and CW Skimmer
Discussion in 'Rig Control, Propagation, Cluster, & Other Softwar' started by IT9PQJ, Sep 1, 2016.
  1. IT9PQJ
    IT9PQJ Ham Member QRZ Page
    Hi all,
    do you know how to connect CW Skimmer to the IC-7300 in order to have large RX bandwidth?
    I've seen that the radio should be set for IF and put into CW mode. In CW Skimmer settings, radio type should be selected as IF-Softrock.
    Once this is done I see the Skimmer window showing 9-kHz instead of 3, but CW Skimmer requires "Audio IF, Hz" and I just can't figure out what value to set in order to have it working right.
    Nico
    F6HRP likes this.
  2. DD5XX
    DD5XX XML Subscriber QRZ Page
    did you get it to work?
  3. IT9PQJ
    No, I did not make any further attempt.
    Nico
  4. DD5XX
    Sad to hear. I am also wondering how it is possible to get CW skimmer to work with the IC-7300 at a bandwidth greater than 3kHz.
  5. KL7IXW
    KL7IXW Premium Subscriber QRZ Page
    Nico: Did you ever get your Icom 7300 to work w/CW Skimmer at 9-kHz spread? - Ward Merdes, KL7IXW Fairbanks, Alaska
  6. IT9PQJ
    Hi Ward,
    no, I'm sorry. I gave up.
  7. KL7IXW
    For what it's worth, I was able to get the broader, 9 Khz spread - and to have CW Skimmer actually show my frequency. The key was to download and "force" my computer to use the ICOM USB driver. Now, if only I could get CW Skimmer to actually decode worth a damn - the way it once did with a 3 Khz spread. It seems to be a bit tone deaf at present. Hope this helps. - Ward
  8. PY2CP
    PY2CP Ham Member QRZ Page
    Just upgrade firmware to 1.30.. it will enlarge it.
  9. PY2CP
    Im having troubles to set it up..in my 2.1 version it doesnt appear ic 7330 on settings. Any help/
    de Enrique
    PY2CP
  10. G4ABQ
    G4ABQ Ham Member QRZ Page
