IC-7100 Clock Failure
Discussion in 'Radio Circuits, Repair & Performance' started by KM4KLB, Jan 2, 2019.
  1. KM4KLB
    KM4KLB Premium Subscriber QRZ Page
    Greetings:
    I have a similar issue as the reported IC-7300 Clock Battery Failure.
    I have have had my IC-7100 for over three years. I mainly use my radio on the weekends and do not have it powered up continuously. I only power it when I use it. I recently took on a large project that limited my time on air and I have gone a few months without being able to use my IC-7100.
    Now, if I leave the IC-7100 powered off at the main power supply for more than a day, the date clears and the clock resets back to 00:00. As long as I leave the main power on, the clock remains corect. I do not notice a difference in any of the settings other than the clock.
    I contacted ICOM about the issue and even asked specifically if the problem could be caused by a dead clock battery. I was informed that the IC-7100 does not have an internal battery and that I would need to have the system serviced to repair the problem.
    Are there any ideas on a solution or a confirmation that the IC-7100 does/does not have a clock battery? It's hard to believe that a clock could keep time without some sort of power.
    Tony
  2. AA5CT
    AA5CT Ham Member QRZ Page
    Sounds like they maybe use what's called a "supercap" for the power source ... and it's gone bad, or something is sapping current from it.
  3. G3ZBP
    G3ZBP Ham Member QRZ Page
    Hi
    NOTE: The backup battery for the internal clock
    The IC-7100 has a rechargeable Lithium battery to backup the internal clock.
    If you connect the transceiver to a power source, the battery is charged and it keeps the correct clock setting. How-
    ever, if you do not connect the transceiver to a power source for a long period of time, the battery will discharge. In
    that case, the transceiver resets the internal clock.
    If you do not use the transceiver for a long period, we recommend that you connect the transceiver to a power
    source at least every three months. The charging period is two days, regardless of the whether the transceiver’s
    power is ON or OFF.
    From Icom IC-7100 workshop manual.
    Martin
    K4AGO likes this.
  4. KM4KLB
    Thanks Martin. I have left the system powered for up to one day in case there was a rechargeable battery with limited success (the time only stays for a few days). I will try leaving it powered for at least two days to see if it will fully charge.
    Tony
  5. KM4KLB
    Attempt #1 failed. I kept the unit powered for 4 days and the clock battery did not last a week. I am giving it another try to see if the charge will hold. If it doesn't, can I change the battery?
    Tony
  6. W9GB
    The Icom IC-7100 is a 21st century radio, hence the majority of its construction uses Surface Mount (SMT) components. While the Part is cheap (in price), it requires skills and tools like that of a jeweler (handling small parts and light touch) in removal and soldering of replacement.
    The IC-7100 radio has BOTH a Seiko Lithium Battery AND an Elna SuperCapacitor (DX-5R5H334U)
    https://www.mouser.com/datasheet/2/129/DXe-5945.pdf
    ICOM IC-7100 Service Manual
    http://www.pd0hni.nl/pdfdocs/7100/IC-7100_service_manual.pdf
    PARTS LIST, Section 6
    Page 5-14 and Page 6-1
    Reference Number: BT6201, Order number: 3020000390
    OEM supplier/part: Seiko ML414HIV01E
    Digi-Key # 728-1052-1-ND : $1.81 each.
    https://www.digikey.com/product-detail/en/seiko-instruments/ML414H-IV01E/728-1052-1-ND/1889213
    ML414H Datasheet
    https://media.digikey.com/PDF/Data Sheets/Seiko Instruments PDFs/ML414H_E.pdf
  7. KM4KLB
    Thanks for providing the information. It has allowed me to review the situation and determine that the replacing the battery myself may require tools that I do not have and it would not be profitable for me to get just for this use. I think it is time to take the unit to the shop.
    The second attempt at charging the battery for 5 days has failed.
    Thanks for all of the information and advice! At least I can make an informed decision now.
    Tony
  8. IW1AU
    IW1AU Ham Member QRZ Page
    Why not to repalce with a typical button battery for clocks? With 100k in series should be not damaged?
  9. KA9JLM
    If you do that you should use a diode, Not a resistor.
    Then you have 1 diode voltage drop to deal with.
    No reason not to use the correct rechargeable battery.
  10. IW1AU
    In principle I agree, but because the recharge current pass throught 100k I don't expect issues even a diode is not inserted...
    I did a screenshot of the original IC-7100 diagram...
