I need stealth, low noise, and gain in the same antenna
Discussion in 'Antennas, Feedlines, Towers & Rotors' started by KD7VEA, May 3, 2012.
  1. KD7VEA
    KD7VEA XML Subscriber QRZ Page
    OK, I have had it with my G5RV. The G5RV is an Okay antenna, but its just not cutting it for me. for the last 2 months, I have been scanning the bands and hearing pile ups, I cant hear the calling station, so I will look up the frequency on a dx cluster board, and see who is calling and where they are. there have been some stations in Yemen, Kuwait, India... but I am not hearing the DX stations. this has been on 20, 17, and 15 meters, and a couple of times on 40 meters. I am most concerned with 10-20. I am running an MFJ 1778 G5RV set up as an inverted sloper as I call it. basically, the top of my antenna is supported with a 30 foot mast, this is the center of the antenna at the feed point. from there, the antenna ends point toward the east, and west. the mast is centered width wise in the backyard, and as the legs go down toward the ground, they angle north slightly so that they stay in the yard. the ends are about 6 feet off of the ground. I am wondering if anyone can give me some tips on how to get a better signal. I don't have a ton of room, and it has to be somewhat stealthy. I dont think I have room for a beam, but was wondering if something like the MFJ rotatable dipole might let me get a little more directive gain by turning it? has anyone done a side by side comparison of a rotatable dipole and a full size wire dipole? does it help that much by rotating it? I am willing to spend a few hundred $$$ if I can actually get on my radio and talk, and hear other stations. also, starting at 10 meters, I have a noise floor of less than 1 S unit, 12 meters 1-2 S units, 15 meters 1-2 S units, 18 meters 3 S units, 14 meters 7 S units, 30 meters 9+ s units, 40 meters 10 over 9 to 15 over 9 noise floor, 80 meers10 over 9 to 20 over 9 noise floor. I do live in the middle of the city, but what can I do to get the noise down, and the signal up, am I just out of options? I love ham radio, but all I can say at this point is that I own radios, I can even use the radios with the conditions. any helpful input is greatly appreciated.
    Jake
    KD7VEA
  2. W9GB
    Can you get any higher than 30 feet?
    The DX stations you are listing are East, SouthEast of your QTH --
    ideally a dipole would need to be perpendicular to that line (N-S alignment).
    The noise floor is due to local RFI sources (e.g. leaky power insulators)
    w9gb
  3. KM3F
    KM3F Ham Member QRZ Page
    I agree. Your anterna is not high enough and without any gain.
    What your missing is antenna takeoff and receive angle is not good at 30 feet.
    Height it'self is not the sole issue but what the angle response of your antenna is at that height.
    I suspect your 'angle' is too high for long distances.
    Said another way, DX angle is usually quite low to the horizon.
    If your antenna angle for example is at 45 degrees it will be low responding the low angle signals.
    I run my beam at about 45 feet and do very well but it's still lower than I would like to have it for 10 and 15 m..
    Good luck.
  4. G4LNA
    G4LNA Ham Member QRZ Page
    To be honest, unless you can get the antenna up and in the clear you are onto a loser, it's the price us city dwellers have to put up with. The antenna you have there is a real cloud warmer, you will probably find the lobe is straight up on most of the lower bands, there is some advantage to that because you'll probably find that there is a fair amount of gain straight up which you can put to advantage.
    In my situation I have a very small garden 40 feet long by 18 feet wide but I've got a 40 Mtr doublet up in that space, one leg winds its way around the loft and the other leg goes out down the garden, the result is an omni directional cloud warmer. This hasn't stopped me working DX, you have to remember the layers are not always level, but are constantly changing, especially in the mornings and evenings this is where we can take advantage of it. I hear lots of pile ups where I can't hear the DX station, on the other hand I work a lot of DX after the first or second call, quite often I work DX that is calling CQ then no one else seems to work them afterwards.
    It sounds like you problem might be more down to high noise level, the worst band for me is 160/80 where the noise level is around S8-9 which I think is pretty good if you look on Google maps my location.
    Also, you have to be patient, conditions at the moment are not the best, so you have to be a bit more patient with the DX.
  5. K4SAV
    K4SAV Ham Member QRZ Page
    As others have already said, a low antenna is not very good for DX. Also with a G5RV on the high bands there are lobes and nulls. If a DX station happens to be in one of those nulls, you may have a difficult time working him, even if the antenna is raised to a good height.
    You have a large amount of noise, almost certainly form local noise sources. For the high bands I would recommend a horizontal antenna as high as you can get it. Also use a very narrow bandwidth on your receiver, no wider than 500 Hz, preferably less. That will improve the signal to noise ratio a lot.
    Utah to Yemen is a difficult path. You have to go over the polar region which makes it more difficult. Also notice that there are no times of common darkness between these two locations, so it's not likely you will be able to work them on 160, 80, or 40, even with a good antenna. (40 might be possible but you will only have a few minutes to do it.) Long path might be possible at times, but they haven't been pointing their antennas in that direction. 7O6T does have a very strong signal but there are a lot of stations you have to compete with, so even if you are able to hear them it will not be easy. They have been over S9 at my location on all bands 40 thru 15 meters (S9 on 80 too but so is the noise lately due to the thunderstorms), however I am listening to them on a 4 element SteppIR and I am a little closer than you are, and I don't have to go over the polar region. All US stations have to compete with Europe to work him. We have to go right over Europe and beyond to reach Yemen. So you are up against some difficult competition. Work on that antenna and just wait until they work most of the big guns, which should be starting about now.
    More info:
    I decided to look at your antenna on EZNEC (including about 75 ft of coax). As expected, you have a nulls in the direction of 7O6T. The bearing to 7O6T is about 11 degrees for you. The gain of your antenna on 20 meters at that bearing and at 10 degrees elevation is about -9 dBi. 15 meters isn't any better. It's also -9 dBi gain. 17 meters is a little better, -5 dBi. You hit nulls on the antenna on 20, 17, and 15 meters. It's no wonder you can't hear them.
    Jerry, K4SAV
  6. WA1FOK
    WA1FOK Ham Member QRZ Page
    When you hear these pileups are other stations in your general area hearing the dx? Just because someone is working the dx does not mean you should be able to hear the dx. I have a tribander and see dx on the cluster all the time that I cannot hear. When I check the stations that are reporting they are usually in europe which means that I do not have propagation to the dx.
  7. NY3V
    NY3V Ham Member QRZ Page
    I suggest you try operating digital mode JT65A.
    [video=youtube;shoqvoVfekw]http://www.youtube.com/watch?v=shoqvoVfekw[/video]
    It is low power and you can use this site to find out what other worldwide JT65A stations hear your signal and how strong it is. http://hamspots.net/wsjt/
  8. WB2WIK
    If it's a "classic G5RV" (102' doublet center fed with about 31' of ladder line, and then coax to the station), don't expect much from it on 17, 15 or 10 meters because it's a lousy design for those bands. It should be okay on 80-40-20-12 meters, although on 12m it has large peaks and nulls and of course if a station is in a null you probably won't hear them even if your noise level was very low.
    High noise levels aren't always the case in "the City." I live in a slightly larger town than yours (I'm in Los Angeles, in the city itself) and my noise levels are normally very low. It's a matter of finding the noise sources and eliminating them one by one, until you find all the local noise is coming from power lines or neighbors. I worked with the electric company to virtually eliminate my power line noise (which was all coming from old hardware and insulators, which they replaced), so that leaves only the neighbors. I even worked with them the best I could and eliminated two major noise sources at two neighbors' homes (a sodium vapor lamp at one, and aquarium heater at the other). There are still some, but the noise is way down from what it was originally.
    "Most" of the noise is usually generated in your own home, from various appliances including computers, monitors, chargers, plasma TVs, and lots of other things.
    A rotary dipole that's a good design and actually works on 20-17-15-12-10 meters, and installed on a rotator at 30' above ground will slam-dunk outperform your G5RV, period. The only band where the G5RV might work just as well as the rotary dipole is 20 meters. It will never work as well as a rotary dipole on 15 or 10m, and not on 17m, either.
    But the rotary dipole really needs the rotator to be effective; otherwise you have an antenna that works in two directions and is lousy elsewhere.
    The Yemen operation, for example, was S9 at my home in L.A. last evening on 17m SSB (18.145), really quite strong and often stronger than all the guys in the pileup calling them up the band on .150-.155. They peak at about 15-20 degrees (NNE) from me, and that would be about your beam heading also. It's the other side of the world from here and the short path is nearly over the magnetic north pole, so it can be fluttery -- although last night, signals were actually quite clear and not much flutter.
  9. K4SAV
    WIK is correct. The bearing for you is about 17 degrees. I inadvertently put the cursor on Idaho instead of Utah the first time. So your antenna gain is a little more than what I quoted, but not by a lot.
    Compare that to my bearing for 7O6T, which is 46 degrees and you can see a significant difference in path.
    Jerry, K4SAV
  10. K7MH
    K7MH XML Subscriber QRZ Page
    Also, just because you can hear the pileup, it doesn't mean that you should be able to hear the DX.
    That area of the world is not all that easy to get into from the west coast, or close to it. Much easier from the east coast and of course most of 4-land. I think you are expecting too much from a simple wire antenna that is a few feet off the ground.
    I can hear 7O6T on 17 CW quite well most of the time I have listened there but not on SSB and not very well on 20 either mode. Other than 17 and 20, I don't really expect to hear them well at all. I have a 2 element quad at 45 ft. and I am about 400 ft above sea level with a pretty good shot to the north and east.
    I'd look at getting a junior beam up at least. A rotatable dipole would work better than what you have and is easier to get it up high sometimes. I made one for 15 meters from the handbook as a novice and used an armstrong rotor. Making one for 15 or 20 (single band) is cheap and easy.
    for beam headings and distances you can plug in your grid locator here;
    http://www.dxzone.com/cgi-bin/dir/jump2.cgi?ID=14599
