I need some good video advice ( external video for a Icom 756pro )
Discussion in 'Homebrew and Kit Projects' started by W6VHK, Oct 7, 2016.
  1. VE3TMT
    VE3TMT Ham Member QRZ Page
    Okay, I see where my confusion was....because the contacts are facing up on J301, I thought the pins were reversed. Looking at the interior view again, I see my taps are on the correct end of J301 to line up with the proper pins on J891.
    CRISIS AVERTED!!
    I'll be glad when this one is done.
    KA9JLM likes this.
  2. W6VHK
    W6VHK Ham Member QRZ Page
    I got my connections at J-301 ( on the front board ) ...in retrospect I should have from the main board ...higher up the food chain and closer to the source. The two flat ribbon cables that go from the main board to the front board are shielded and since I needed slightly longer ones for my project I used unshielded ones. Sometimes my display has a slight jitter and I am wondering if that could be why .....a project for another day.
  3. VE3TMT
    Hi Darrell,
    I got the 24-pin FFC connectors in today and they are just too small to comfortably work on. I broke a couple pins off just try to bend them out a bit to mate up. So it appears the only way I am going to be able to tap is to go further out on the display board. I am not going anywhere near J301. It has had too much soldering. The tap points out from J301 are easy to get at, except 4 of the 5, not counting ground are on the backside of the board. So the board would have to be separated from the front panel to get at them, this is getting messier all the time.
    As for J891 on the main board, it's too crowded in there for me to work. The RGB lines are pretty easy to access in the resistor bank, but the HSYNC and VSYNC lines need to be tapped at the connector itself, and one of them is on the inward side of the connector, too cramped in there.
    So at this point I am debating whether to continue or not, I certainly don't want to risk and unrepairable damage to the radio.
    FWIW, the two replacement cables I used aren't shielded either, and I don't get any jittering in the display at all, even running the amp.
    Max
  4. VE3TMT
    Hi Darrell,
    Just an update, I have tried yet another 24 pin connector that did not work. In the meantime I ordered some 24pin 1mm pitch breakout boards from China, but again the soldering of the connector may be just too difficult. I then stumbled across these:
    24 pin 1mm ZIF to DIP adapter, this is what I have been looking for all along. Two pieces arriving in my mail today. Should be a simple matter to solder them back to back, then tap off the required pins and heat shrink the whole assembly. I have the two smaller ribbon cables already here. This way the entire mod will be reversible if needed. As I already have the converter board just sitting on the shelf, I figured I might as well try one more time. Will keep you posted.
    Max
  5. KA9JLM
    Where did you find that connector ?
  6. VE3TMT
  7. VE3TMT
    I've decided to go this route:
    I'm going to put two back to back then jumper the 24 pins. One side of the board is 24 pin 0.5mm pitch, the other side is the required 1mm pitch. I think this will be much easier. I ordered ten boards, ten 24pin ZIF connectors and ten ribbon cables for $16 CAD off Amazon.
  8. W6VHK
    Any luck yet?
  9. KA9JLM
    It has been awhile.
    How is yours working ?
  10. W6VHK
    Works great! I have been working on other things but will go back to it soon as I want to try another RGB / VGA converter ( with a line doubler ) to see if that will improve the resolution ...it should.
    KW4EK and KA9JLM like this.
