ad: Alphaant-1
HR2.0 Episode 146 - BTECH U25D Amp Testing
Discussion in 'Amateur Radio News' started by KC5HWB, Aug 8, 2018.
  1. KC5HWB
    KC5HWB Premium Subscriber QRZ Page
    KM6SIK, KD5RJZ and NU4R like this.
  2. N1NDN
    N1NDN XML Subscriber QRZ Page
    I don't believe that the small cable from the radio to the amp would induce that much attenuation! I believe either the amp doesn't really go in to bypass mode when its shut off or you have a defective cable. Something else to consider is that you're output of 25 watts with the amp on is either very good if its really getting a quarter watt input or not good at all if its getting a full 5 watt input. Further testing with a different SMA cable should be posted, there's too much of a mystery here to consider the amp to be ok or not.
    KC5HWB and WQ4G like this.
  3. WM3M
    WM3M Ham Member QRZ Page
    I have had this amp for a couple weeks now, the AMP-U25D for DMR, it works, sort of. I use it with an MD-380, at 5 watts into the amp. Using the mic on the U25D, with the connection to the HT there is steady clicking, pulsing, ticking type sound on my signal. It is very noticeable and distorts my DMR signal. I tried everything I could think of, grounding everything, ferrite chokes on all leads, different locations, pulsing still there. When I use it just as an amp, RF into the U25D from the MD-380 only, signal is fine and clear. Measuring wattage on FM, it puts out about 35 watts, do not have a way to measure wattage on DMR. I really wanted to use the U25D with its mic and speaker and not just as an amp, so not sure it is worth it, but its the only amp for DMR I have found. The loss noted in the above video is not from the small cable, if you turn off the amp it does not go into by-pass, it does not pass the RF, so if the amp is off, there is not RF out. Using just as an amp and not with the supplied mic, cables, etc. it does work well on UHF DMR, I can work several more UHF DMR repeaters at quite a distance, using an outside, roof mounted antenna. Emory WM3M 73
  4. AA1PR
    AA1PR Ham Member QRZ Page
    adore your videos
    but they are way too long
    K0WJ and KI6BQL like this.
  5. KG2C
    KG2C XML Subscriber QRZ Page
    I stopped watching when the host said "We can't hear fast enough to hear 33 times a second". I think he would have benefited from reading the Wikipedia article on TDMA before telling people how TDMA works.
    K0WJ, WD8CRT and NU4R like this.
  6. KD5RJZ
    KD5RJZ Ham Member QRZ Page
    Review is useless without knowing the insertion loss of the cables.
  7. KC5HWB
    I think you are right about the amp not passing traffic when it is powered off - which is a poor design, imo. But 25-watts out with 5-watts in is pretty standard for an HT amp.
  8. KC5HWB
    Thanks for this info - you are someone who actually used the amp, so your notes are accurate. I think the fact that the amp doesn't pass RF when powered off is a poor design, but I didn't have any of the clicking in my TX that you are describing.
  9. KC5HWB
    Because Wikipedia, written by any schmo with a keyboard, is always accurate, right?
    Also, if you read the article you link, it never contradicts what I said. I can show you articles online that say 33 m/s, 30 m/s or 36 m/s. Perhaps it is a secret that no one actually knows
  10. WP2ASS
    WP2ASS XML Subscriber QRZ Page
    The last real technical review I saw of one of these amplifiers (possibly branded a different name) showed that at 35 watts it couldn't meet itu standards by c 3.5 dB.
    That means if you hook it up to an antenna, you are in violation. That also means as you turn the power up, it gets magnitudes worse.
    As such, use at your own risk. Most of the ChiCom garbage has zero filtering. It's YOUR responsibility to not be as ignorant as a CBer.
    --Shane
    KD6VXI
    KG5KOG, VK4LC, KA2FIR and 2 others like this.
  11. WD8CRT
    WD8CRT Ham Member QRZ Page
    30 mS you mean? = 0.03 S (second)
  12. KG2C
    There's other sources if you don't trust Wikipedia where you can double-check that this is a data transmission
    The point I was making was that you as a host of a very popular ham show that attempts to educate and entertain people, should make an attempt to share correct information and not to share incorrect information. We have plenty of forums for the sharing of wrong information and your channel is a great way to educate people and share the correct information as you usually do. All I suggest is that if you are going to talk about TDMA then maybe check that what the radio does is send data not analog audio in two separate streams (slots) that are switched between several times per second. Then that data is converted into analog audio that is played without interruption.
    If you don't like Wikipedia as a source, that'f fine. I don't claim that everything there is correct or even exhaustive on any topic and there's plenty of other sources where you can read up on the topic you were discussing in your show.
    KA2FIR, K0WJ and KD5RJZ like this.
  13. KD5RJZ
    Some basic test equipment (a real watt meter and dummy load and maybe a cheap spectrum analyzer) would have vastly improved the quality of this review. What is the point of talking about the gear without knowing it's technical specifications. You need to add value to the product and I am not sure how a video of questions and speculation does that.
    KA2FIR, AG7LR and K0WJ like this.
  14. ND5Y
    ND5Y Ham Member QRZ Page
    Any schmo can make YouTube videos full of misinformation too.
    KA2FIR likes this.
  15. KC5HWB
    It would be a good test to put one of these behind a
    Overall I do agree with you. But I never said that TDMA (DMR) sent analog audio. The vocoder converts digital audio into analog and vice-versa, because humans hear in analog.
    My comment in the video about the dual timeslots didn't have anything to do with analog/data, though. It was an explanation of how 2 timeslots can exist on the same frequency and not interfere with one another.
ad: Schulman-1
