ad: Hamts-1
How to remove enamel from (toroid) wire?
Discussion in 'Homebrew and Kit Projects' started by AA7EJ, Jul 12, 2017.
  1. KD0CAC
    KD0CAC Ham Member QRZ Page
    Never bought any , I get so much of it free from many sources , problem is I do not know its properties .
    Scrapping and or very fine emery cloth , in that order has worked for me .
  2. KL7AJ
    I have a curved ceramic finishing tool that works wonderfully for scraping magnet wire.
  3. N1OOQ
    N1OOQ Ham Member QRZ Page
    I just scrape it with an x-acto. Just don't press down very hard, and keep the knife moving. Holding it still on the wire is what causes nicks.
  4. AA7EJ
    AA7EJ Ham Member QRZ Page
    Just installed three small cores using both 100W iron and scrapping with x-acto knife.
    Had better luck with scrapping, solder get the wire too stiff to mount and harder to control how close to the core it should be tinned. Works for me on #26.
    I'll try nail polish remover on next set.
    73 Shirley
  5. KH2G
    KH2G Ham Member QRZ Page
    GC used to sell a stripper solvent you stuck the wire in and wiped it off. Acid based I assume.
  6. WA7PRC
    WA7PRC Ham Member QRZ Page
    #10-2602 & 10-2616, "Strip-X", aka methylene chloride. IOW, paint stripper.
    KH2G likes this.
  7. AA7EJ
    I had a good luck removing paint from metal surface using household oven cleaner.
    But it took a while.
  8. WA7PRC
    The active ingredient in oven cleaner, also drain cleaner is sodium hydroxide, caustic soda, or lye (link). It also eats skin... it's nasty stuff.
  9. N1OOQ
    Methylene chloride is pretty nasty too... be careful if you use stuff like this. At least with lye, you can rinse it off and be fine.
