How Does Meteor Scatter Work
Discussion in 'General Announcements' started by G3YWX, Nov 8, 2019 at 10:42 AM.
  1. G3YWX
    G3YWX Ham Member QRZ Page
    Meteor scatter is a form of propagation mode that is used for medium distance ham radio communications, especially on bands like 144 MHz. It enables contacts to be made over distances of 1500 to 2000km on these frequencies allowing contacts to be made over much longer distances than might otherwise be possible.
    As the name implies, meteor scatter uses the fact that meteors enter the upper reaches of the Earth's atmosphere. When they do so they burn up leaving intense trails of ionisation - typically around the same altitude as the E region in the Ionosphere. Although the meteors are very small, and the trails not that large, it is still possible to use them to "reflect" radio signals and thereby extend the range over which a signal can travel.
    Amateur radio activity tends to focus on times when there are meteor showers, but meteors are always entering the atmosphere. The meteor showers give much greater numbers of meteors and also the meteors tend to be larger, which leads to larger ionisation trails.
    Find out more about meteor scatter and how it can be used by commercial operations as well as radio amateurs in our article on Electronics Notes.
    https://www.electronics-notes.com/a...tter-burst-communications/basics-tutorial.php
    AI3V likes this.
  2. K8ERV
    K8ERV Ham Member QRZ Page
    Sure makes for short contacts. I used to use it, on 6m as I recall.
    TOM K8ERV Montrose Colo
  3. KM1H
    KM1H Ham Member QRZ Page
    Most early mornings around dawn is a good time to work random meteors on 6 and sometimes 2M. Ive made 6M SSB contacts with as little as 10W in the 60's when mountain topping to give out the "rare" states of NH and VT.
    Carl
ad: vanity
