ad: PortRo-1
Horse fence for antenna
Discussion in 'Antennas, Feedlines, Towers & Rotors' started by KI4JFJ, Jan 13, 2009.
  1. KI4JFJ
    KI4JFJ Ham Member QRZ Page
    I have a brainstorm for an HF antenna. I'm limited as to how long a wire I can run for an HF antenna, but I have a 4 strand high tensile wire fence for our horses that covers about 3 acres. The top wire is run through insulators at every post & was connected to a fence charger. The charger no longer works, so it won't be a problem. The fence is continuos, but could be unhooked on one side to make a long wire or split it. If I run coax to the fence, fasten the middle wire to the top fence wire & run the shield wire to the ground, would it work for an HF antenna? My radio has a built in tuner, so it should tune.
    Does anyone know if this would work and does anyone know of someone who has tried this system?
    I would appreciate any any comments or info anyone can provide.
    You can Email me @ Gopreach@lorettotel.net
    Thanks & 73,
    Larry KI4JFJ
  2. KB7QPS
    KB7QPS Ham Member QRZ Page
    Interesting concept. It's worth a try and see how it works. The thing I like about ham radio is you get to experiment.
    Here's a few thoughts.
    1) Your antenna tuner may not have enough range to tune to the fence if indepedence mismatch is too create. Even if it does tune, you will lose quite a bit of signal as it goes back and forth along your coax line.
    2) I used electric fence wire in high school because I didn't have enough money for copper clad steel. My antenna didn't work very well (could never get DX, usually only in North America).
    3) It's awfully low to the ground so you will lose quite a bit to ground absorption and your angle isn't optimal.
    Like I said though, try it and see how it works. I used probably 10 different antennas before I found the one I liked the best.
  3. M0PDQ
    M0PDQ Ham Member QRZ Page
    i'm no antenna expert (or even knowledgeable!) but could you run a wire with the fence cut to lenght to make a dipole ?
    would probably perform better.
  4. KL7AJ
    Depending on your ground conditions, this could either be a moderately effective Rhombic of sorts, or a worm toaster. I'd say try it and see.
    eric
  5. n0aih
    n0aih Banned QRZ Page
    fence wire antenna
    Yes it will work, if it is long enuff.
    Insulate the two ends from each other so it appears (electrically) to be a random length wire. It will have a high ange of radiation but who cares? At the onset load at low power to make sure it in fact a random length (electrically). If it is too short (electrically) it may not be friendly to your transmitter.
    n0aih
  6. K0RGR
    It might make a very effective receiving antenna, particularly for the lower bands. I suspect it's too low to be an efficient transmitting antenna, but you might be pleasantly surprised.
    I once had a 160 meter loop, not too high off the ground. It produced 'pipeline' results to stations in Michigan, and pretty much nowhere else. It didn't work well at all on the higher bands.
    You might also consider using it as a counterpoise for a vertical. If you could devise some switching, the loop might be a killer low-noise 80 and 160 meter antenna, and the vertical would be a great antenna for transmitting on those bands.
  7. KL7AJ
    RGR:
    There was a time, once upon a time, when I believed you couldn't possibly make an antenna too long. I had to modify that opinion when I loaded up a 420' broadcast tower on 160. (I was chief engineer of KJNP at the time...1170KHZ, and I had access to it after hours).
    That monster didn't work worth BEANS on 160....it was pretty much a longwire straight up! Had MUCH better results....EVERYWHERE....with my 80 ft tall inverted L.
    Eric
  8. AC5DE
    AC5DE Ham Member QRZ Page
    Barb wire
    We loaded up a barb wire fence at field day one year. It should work results may not be fantastic, but it is worth a try. I guess you could place the horse against it to tune to different wavelengths. Let us know how it works.
  9. KL7AJ
    That should stirrup some activity. :)
  10. N7WR
    N7WR Subscriber QRZ Page
    It will "work" but no telling how well until you try. I agree with others that your rig's auto tuner might not have enough range to tune it but a manual tuner should
ad: hrd-2
