Homebrew tuner
Discussion in 'Homebrew and Kit Projects' started by KF4ZGZ, Jul 14, 2017.
  1. KF4ZGZ
    KF4ZGZ Ham Member QRZ Page
    Something I have wanted to build for a long time.
    At a hamfest Saturday, I picked up the variable capacitor for 10 bucks.
    Sunday, the junkbox produced the rest of the parts and I kludged together a working unit using another coil that was a shunt coil for a mobile antenna. Even though the coil was small it worked on 20m and up.
    I then made the current coil and mounted everything permanently on the board.
    According to my MFJ-259B it will tune my 80m loop on all bands to 1.5 or better.
    Put it in line yesterday and I was told I had rf on my signal.
    I listened to myself on 80m using websdr this morning and it sounds more to me like an 60 cycle hum.
    Any ideas on where to look to solve this?
    I plan on sourcing a metal enclosure today to see if that helps.
    Another thought is to finalize all the connections by soldering .... which I plan on doing anyway.
    Matt
  2. AF6LJ
    The metal enclosure should do the trick.
  3. N7EKU
    N7EKU Ham Member QRZ Page
    Hi,
    Probably you already checked, but is it (or the coax) near any line transformers (like from a linear power supply or non-switching wall wart kind)?
    Mark.
  4. G3YRO
    G3YRO Ham Member QRZ Page
    With the right values, an ATU should always be able to give you a perfect 1:1 match !
    What kind of circuit are you using?
    If you're using it to feed a Loop, is it a proper Balanced design?
    Roger G3YRO
  5. AA7EJ
    AA7EJ Ham Member QRZ Page
    Since the tuner is in "work in progress" state - how about temporary "enclosure" likes
    large cooking pot or turkey frying aluminum pan?
    Not sure how you getting 60Hz into "just" tuner, but...
    Can you post the schematic?
    73 Shirley
    PS One of the better "sources" for home-brew tuners is hardware from ARC5 WWII US transmitters - both capacitors and coils.
    You cannot beat the rugged mechanics, but most people just throw them away!
  6. KF4ZGZ
    The circuit is a basic L-network. My intent is to use it with 600-ohm feedline and a dipole.
    The loop just happens to be what I have up right now.
    The coil is 60-70 turns, and I have no idea what the variable is.
    Matt
  7. N5DMC
    N5DMC Ham Member QRZ Page
    Looking good so far Matt, also.....A grounded enclosure is an active component of your matchbox, good luck.
    Doug,
    N5DMC
  8. KF4ZGZ
    UPDATE: The tuner is actually fine!
    Apparently my IC-706 MKII is picking up ac line noise.
    Used the tuner (with newly completed popcorn tin enclosure) on 80m this morning and it is all FB.
    Can't wait to try it on a dipole.
    Now to figure out the 706 .........
    Matt
  9. AA7EJ
    I guess the kid was right, at least this time.
    It may not be that easy to find the real source , but it would be better than just putting band aids (toroids) here and there.
    Patience is a virtue.
    Good luck.
    73 Shirley
  10. KF4ZGZ
    pic test ..... goodbye photobucket
