Homebrew Spiderbeam, not using the commercial kit...
Discussion in 'Antennas, Feedlines, Towers & Rotors' started by AE7F, Jan 4, 2012.
ad: K3QNTad-1
  1. AE7F
    AE7F Ham Member QRZ Page
    In looking at various antenna designs and many DIY ideas, I have come back to the idea of the Spiderbeam. As in other threads, I would like to make my own antenna. In consideration of this, has anyone built a Spiderbeam without buying the kit?
    I've compared spreaders in another thread:
    http://forums.qrz.com/showthread.php?327590-Spreaders-Spiderbeam-vs-MaxGain-Type-1-which-is-stronger
    I think the MaxGain Type 1 spreaders would be stronger and less expensive. This is what I have found so far in terms of a DIY, 5-band spiderbeam:
    rope & wire
    47 + 15m = 62m kevlar used for guying the spiders: ~ $37
    82 + 22m = 104m dacron used to support wire elements: ~ $41
    73 + 30m = 103m of wireman cq-532: ~ $64
    spreaders
    4 type 1 spreaders from max gain: ~ $100
    spider
    1 spider - cast, custom, or Cubex: ~ $60
    This comes to around $300 not counting shipping or other parts such as clamps, bolts, etc. Call it $400 shipped. In contrast, the commercial kit would cost around $650 shipped.
    One could save about $30 by using different wire, such as (http://www.homedepot.com/Electrical...splay?langId=-1&storeId=10051&catalogId=10053) and around $80 if using (gasp) PVC pipe.
    The use of PVC is generally discouraged for spreader use but PVC does have some good points. It's cheap and easy to replace. It's easier to work with as well. You can replace your PVC spreaders probably 4 times before you've spent the same amount on PVC as you would have on fiberglass. And by the second or third time, I think you would have the weaknesses worked out to where you could prevent future problems. If you have a crank-up tower, the maintenance/replacement issue is far less of a problem and might even be considered to be a non-issue. Unlike when using fiberglass spreaders, the guy system would have to take most of the weight of the spreaders because fiberglass spreaders can support themselves to a point but PVC would sag too much. However, the Kevlar rope should do the trick. One would also just add more guy points.
    Also, in the Spiderbeam design, you can keep the spreaders horizontal if you want. In contrast, the hexbeam design stresses the spreaders upwards and PVC really sags. I think it would be much harder to maintain hexbeam geometry with PVC than to maintain the horizontal geometry of the Spiderbeam with PVC. I have conversed with some hams who have used a PVC hex design with some success. Breaking doesn't seem to be the problem (due to high flexibility) but sagging is a major problem. This could be dealt with much better on a Spiderbeam.
    Nevertheless, a $400 dollar DIY Spiderbeam that uses the MaxGain Type 1 spreaders sounds interesting to me.
    What do you guys think?
  2. NH7RO
    NH7RO Ham Member QRZ Page
    Hello again, Ben; I suppose you've already done your homework obviously but am wondering if one really needs that much rope for a 5-band Spiderbeam? 166m=540 feet or thereabouts. Since I'm also currently leaning towards a Spiderbeam (either DIY or "storebought") I suppose it's time for me to download their construction manual and look into it further myself. Your recent 5-band antenna comparison was very helpful and I again note that the Spiderbeam has the highest db per pound ratio of the different beams you put in your comparison. While a bit larger than a hexbeam it is still in the same weight class and cost but has a tad more gain. Groovy!
    What I might do if I DIY one of these is use this rope as I've used it for many of my antennas already and I like it a lot:
    http://rwrope.com/outdoors-sporting-goods/sportsmans-utility-cord/sportsman-utility-cord.html
    A 1000' spool of the 150# test runs $35 and maybe $5 shipping=$40 total rope cost (or 6 100' spools would be only $24 + shipping so maybe $30 total rope cost). Although their website indicates polyester I'm thinking it must have some Dacron in it as it handles like Dacron and weathers very well. An added plus is that it's strong, cammo green and is nearly invisible since it's so thin (approx 1/16" is my guess).
    That link to the Home Depot wire is the 18 ga. stranded I mentioned in another thread; it's a good deal in my opinion and is also probably what I'd use as well.
    As for the spreaders I think it would be best to stick with MGS Type 1s or 1Ls unless you really wanted to make one of these beams on a tight budget. PVC may work (with enough guying support) but the weight and extra guying wouldn't be worth the slight savings in my opinion.
    I'd actually be tempted to try out the lighter 1L spreaders to keep the overall weight down as low as possible, too.
    I already have an old New Wave Portapole 33' aluminum telescoping mast that would put my beam up around 30' in the air. Naturally, I want to go with something as light as feasible so as not to overstress my mast as well as be easily raised and lowered by myself if necessary. I currently have my 10lb 17M Moxon on it now and it is guyed at the top and about the 10' level. I really like the mast and hope that it would still be OK to use it for a monster Spiderbeam. I see on the Spiderbeam website that their standard 5 bander weighs 16lbs and the HD version is 25lbs. IIRC.
    As much as I like the KIO/DXE hexbeams I am a lot more tempted to try a Spiderbeam instead. The big wire log periodics would probably be more difficult to build and manage than a Spdrbm, at least in my mind.
    Thanks for starting this thread and I hope you elicit further response. I've also joined the Spiderbeam Yahoo Group which seems like another good place to get feedback, too.
    Now it's on to a bit of research on costs such as for the hub---I see that the Spdrbm people use a flat aluminum plate with stainless U-bolts (nothing fancy) so there's another item that could easily be homebrewed at minimal cost. I've been saving an old table saw's top that that I have out in the back shed for such a project---it is made of thick aluminum that'd be perfect for cutting down and drilling!
    73 until further ruminations come to mind,
    Jeff NH7RO
  3. NH7RO
    Just realized that spiderbeams (I'll abbreviate as SB from now on) require a balun at the feedpoint so we better budget that into the total cost.
    Although the SB web site has the W1JR type coax choke baluns for $75/$119 (kit/built) I suspect that is something that could also be easily homebrewed and installed in a small PVC junction box with the proper toroids and teflon coax. Either way, it's another cost and essential item that shouldn't be overlooked.
    One other thought as long as I am here is: What about adding 6M to a SB? Has it been done by anyone with any success? That's one thing I do like about the KIO and K5BOB hexbeams; they have the option of a 6th band/6M.
    It would add to the weight, cost and complexity so it may be preferable (at least for me) to build a separate 6M monoband SB instead. Since I already have a 5 el. Yagi for the Magic Band I would be more interested in attempting a 6, 7 or 8 element SB at some point. In the meantime, it doesn't hurt to dream or start planning.
  4. AE7F
    We must be on a nearly identical frequency. About an hour ago I thought about the cost of the balun and also 6m add on to the SB....
    I have indeed been through the specs document as well as the construction guide for the SB. Their dBi quotes are strange but the dBd gain quotes seem about right for what they classify as a yagi design. The construction guide is a bit strange and that's one criticism you'll see on eHam reviews. If I use their guide, I will actually digitally edit the .PDF file for my own use so that it makes more sense to me. I will move around the tables and specs so that they are in a logical order that makes sense to me so that I don't get things wrong.
    The balun can definitely be done yourself. IIRC, they have a line or two in the construction guide where they talk about the balun. However, I think there is mention of just using slip on choke beads as well. Also IIRC, many of the hex beam guys use the choke beads. Also of interest is that my antenna tuner has a built-in 4-1 balun. Some tuners do. However, there is a reason they put their W1JR type balun up at the antenna itself! There are probably many ways to accomplish the choke balun so yes indeed, it has to be included in the cost but I think there might be $25 or $30 dollar savings to be had here...
    I haven't asked about 6m but I did ask the SB group about stacking an 11-element 2-meter beam above the SB. Didn't have a response last time I checked. I'd like a 6m addition myself but I'll settle without one for now if I have to. 5 bands means a ton of wires.
    The Titanex DLP-15 I looked into also had 40m on it as well. I still never could figure out which wire was the "full 40m dipole" on it though....
    I am a member of the SB and HB groups and both have been very helpful, but I think there seems to be more people and responses on the HB group. It's my intention to use tips and tricks from both antenna designs on my own.
  5. AE7F
    Glad we are looking at the same thing and thanks for your continued input.
    Okay, thanks for that rope info. The fact that you've used it before is a useful bit of information. I dig the almost invisible part. With that much length, you could guy the heck out of the antenna. I will for sure consider this and the HD wire as well.
    Well, I can set the budget to whatever within reason, so the PVC idea is more of a strong curiosity. As mentioned, I have talked to several who have made/are making it work on the hex beam. The one thing I don't know is how much heavier a 15ft section of PVC is than fiberglass. I do know that I can get all the PVC I want locally without shipping, so $20 bucks buys me enough for the job. Then I thought, that's the shiny white stuff for underground use and it would look ugly and so forth. So I priced the grey UV and corrosion resistant electrical conduit PVC and it would cost me about $30 bucks. It was in 10ft swaged sections, which might be a dealbreaker for me, but if I can get it in 15 or 20ft lengths, I am strongly considering trying it. My mast is strong enough to hold the weight and I can crank it up and down, so I can bring the mess down if it doesn't work.
    But think about how easy it would be to mess with the SB design when using PVC. You can put holes anywhere in the PVC without as high a risk of splitting. For guying, you could put an eye bolt right through the PVC with a nut and washer on one side, then simply guy to the eye bolt. You could pin any jointed sections. Or you could skip the eye bolt and just run the element wire or guy rope right through the PVC mast (of course I would also use a bushing to prevent freying or snagging of the rope/wire). I haven't worked with fiberglass but I don't think I'd want any cuts, knicks, or holes anywhere that it wasn't absolutely necessary. You can always still use clamps but if the PVC sections are full, jointless lengths, and if clamps cost more than nuts and bolts.......
    The PVC would definitely have some sag. This is a real issue. But a certain amount of flexibility might... might help in the kind of wind we have here. Don't know, I've never had a PVC spreader up in the air! I think the sag would really show up when you guy around the perimeter to make (when viewed from above the beam) a diamond shape.
    However, with the cheap rope you posted, you would have so much, and with it being such small diameter, just double the guying. I would prefer thicker stronger rope but with that diameter, I may not mind the extra guying if it's easy on the eye due to its small size anyway. Dunno, just thinking aloud.
    For your location, you probably could use the lighter materials. Here, they would most certainly blow apart in the spring winds.
    Ditto. This is exactly the conclusion I came to. Having some people who have already tried out a design yields more confidence to try it yourself, albeit at least myself, with some (possibly strange) design changes..
    The hex guys have used everything from plywood to the bottom of a wooden wire spool to ... you name it. The SB kit includes plate that is only 2mm thick but it sandwiches the spreaders between two that are bolted together. The mast clamp bolts to the flat plate. One eHam reviewer said the clamp bolts would shear off when the beam torqued in the wind. He just used larger bolts and I think additional clamps.
    I've seen a few hex hub plate designs, one of which was simply a large plate of 1/4 inch aluminum and you would just use 2 clamps per spreader. No sandwiching the spreaders and such. Not an engineer so I don't know which is better but I do know you can get a plate of aluminum for $25 bucks. Just drill the appropriate holes and add 8 clamps and voila. This design would probably work best with a "floor flange" on either side of the plate, which flanges are bolted to your antenna mast.
    Or there are the cubex spiders or the custom spiders made by Rick Adams (rickadams.net). Biggest challenge is coming up with one that fits the spreaders of your choice. That's why I may have to just use the aluminum plate + clamp method, which can easily adapt to the proper size.
    If I were to choose PVC and it fails quickly and catastrophically, I will be the first to come back and laugh with everyone else. But if I use it and it works....
  6. AE7F
    Home Depot wire: $24 (no shipping, local)
    inexpensive rope: $45
    kevlar rope: $45
    UV resistant PVC spreaders: $30 (no shipping, local)
    spider hub plate assy: $75 for aluminum plate, 8 clamps, 2 floor flanges & bolts (no shipping, local)
    choke balun: $50? for DIY (don't know, never made one like in the SB manual)
    tuner balun: ($0 - included in tuner)
    $269 as above, or $339 with MGS4U Type 1 spreaders.
    This drives the cost per average dBd of the SB down to $66.25 or $83.49, depending on spreader type used. See: antenna comparisons.pdf
    If either of the above configuration would survive the WX here, for that price, it would be a killer bang for the buck - much better than any of the other antennas I compared. The key is whether or not it would survive because the electrical design would certainly work well enough.
  7. AE7F
    As far as experimenting with PVC spreaders, this obviously would make quite a difference as well:
    Schedule-40-versus-Schedule-80
    Depending on the weight, it looks like Cantex Schedule 80 Conduit would be much better than Schedule 40 water pipe:
    Cantex Schedule 80
    Sold at local Home Depot Stores:
    Cantex Sch. 80
    Is UV, flame, and crush resistant and has a specified temperature range of -20f to 122f:
    Cantex FAQ
    You would have to find an OD that would work with preexisting spider designs but if you design your own hub, you could use any OD of the stuff and make it work.
    And finally, grey is much better aesthetically than white! :D
  8. KC8VWM
    KC8VWM Subscriber QRZ Page
    Using PVC is actually very heavy and it sags considerably in runs longer than 5 feet because it is not "stiff"
    Epoxy resin fiberglass fishing rods are very strong and yet lightweight by comparison. Thier only downside is they are not very "crush" resistant.
    However, I will attempt to visualize and present a few ideas in this thread for consideration using some of my own past antenna contruction photos.
    Here's a lightweight hub which was purchased at a local farm supply store. These are actually lighter than the idea of using heavy steel clamps installed on a chunk of aluminum plate but yet serves the same purpose.
    The hub I am using is basically originally intended to hold 1" diameter poles together to construct a frame. The frame, when constructed can hold a tarp, green house or similar temporary shelter of some kind.
    They are very sleek and lightweight, but yet very strong and rigid. They are well designed and originally engineered and intended for erecting structures involving weight bearing structural stress. They are also well suited for long term use in outdoor enviroments.
    These also happen to hold fishing poles for constructing antenna's quite nicely too. [​IMG]
    The photo above and below shows the hub which is to remain permanently attached to a short mast section. The short mast is simply slid into a longer lightweight mast and so no clamps on the hub are ever required to be removed, disassembled or reinstalled during setup or takedown operation.
    Hub permanently installed on short section of lightweight aluminum mast. Poles can be removed from hub for storage. No tools are required for assembly/ dissasembly.
    To raise the antenna higher, we simply add the desire amount of lightweight aluminum mast sections.
    The ends of the fiberglass rods have been taped to help protect them from damage and helps them to snug up nicely inside the tubes and to keep them from vibrating in the wind. A section of shrink tubing was also installed on the fishing rod and it is too big to fit inside the aluminum tubes. What this does exactly, is it ensures the rods are installed at exactly the right position when fitting them inside the tubes. The rods can't be installed too far inside the tubes or too far out. They will be inserted at the perfect spot everytime. This also demonstrates how the antenna will quickly break down and disassemble for storage.
    Prepare the poles to mount inside the tubes using a pipe cutter:
    I am also using some Dacron line on the hub itself to function as guy wires to help secure it in place.
    Antenna wires are mounted on the poles using UV resistant, mil spec. zip ties mounted to the spreaders and all antenna wires are routed in the following way.
    Hopefully this clarifies things for your project.
  9. NH7RO
    Thanks for all your photos and input on this, Charles. We have a lot of those tarp-frame hubs in use over here in Hawaii; just about every driveway has a tarp carport of some sort made with those hubs available at Ace Hardware. Good simple and inexpensive solution for 1" fiberglass.
    Ben, I appreciate your argument in favor of PVC and you make quite a lot of very good points---but like Charles pointed out, it will sag bigtime, IMO.
    Try it out though as we never really know for sure until we try, right?
    I have seen pix of a hexbeam (at least a 3-bander 10-15-20m) that was made with PVC and wooden dowels inside the first part out from the hub to stiffen it---apparently it worked fine---so what the heck, give it a try and if it doesn't work we won't snicker one bit. Experimentation is one of the great aspects of ham radio.
    Lots more to say today but am off to work for several hours now---will reply further when In get back home. Keep the thoughts and info coming, guys!
    73, Jeff
  10. AE7F
    Yes Charles, thanks for your contributions. Great ideas. How sturdy is your setup? Great idea on the hub. I will price quote when I find some...
ad: Morse-1
