HF transceiver suggestion
Discussion in 'On the Road' started by K6OFG, Mar 26, 2019.
  1. NW7M
    NW7M Ham Member QRZ Page
    Hi Steve,
    I don't think any [amateur] transceivers will have that wide spec for supply DC voltage, because the final PA is directly connected to DC-in without any voltage transformation and its output [and I believe IMD] will degrade much with dropping voltage. In my case, I was trying to avoid using another battery for some reasons, and the solution was a voltage booster. I'm sure you can find a very efficient one. Mine is 40A rated and it always cold [highly efficient]. It has an issue as well, on some bands you can hear its noise, but it's narrow and floating all the time, so the chance it will really bother you is minimal.
    Alexey / NW7M
  2. WD0BCT
    As long as I keep my battery voltage within spec of the transceiver (13.8V +/- 10%) I'm happy! So is the transceiver.
  3. K6OFG
    K6OFG XML Subscriber QRZ Page
    Maybe I do have a problem. The Icom is the only radio I have ever used mobile so don't have much else to go on other than watching the internal power meter and reports from other hams.
    Further research in that respect is needed.
    Thanks.
    And my quest continues.
    Steve.
  4. W4EAE
    W4EAE Subscriber QRZ Page
    If you do not have them, a watt meter, dummy load, and a variable mains power supply should be easy to borrow if you have a good group of other hams in your area. If I asked around here, three of four of them would probably not only be willing to let me use their equipment, but would also want to come and help me run the tests.
  5. K0UO
    K0UO Subscriber QRZ Page
    I love Icom radios but they're very voltage dependent, (when you go below 12 volts, don't expect them to work properly) as pointed out. MOst of my friends and myself use Kenwood 480 s in our RVs and don't have any major issues. On the 7155 morning group out of over 30 rvers most all of them are running the 480s, that speak something of that radio.
    I have tried running mfj and other voltage boosters, but sometimes they put out a digital noise.
