ad: rfparts
HF/6m Base Station
Discussion in 'Survey Center' started by K2CLH, Oct 22, 2011.
Which radio is best for a base station and also best for it's price?
  1. TS-480SAT
    36.8%
  2. TS-570S
    10.5%
  3. TS-570S(G)
    52.6%
Multiple votes are allowed.
  1. K2CLH
    K2CLH Ham Member QRZ Page
    Hello from K2CLH! I posted a thread asking what HF/6m base station is best under $1200. I have narrowed it to the three on the poll. I would also like you to reply please and tell me the difference between the S and S(G) version.
    73 thanks,
    K2CLH
  2. KG4NEL
    KG4NEL Ham Member QRZ Page
    http://www.universal-radio.com/catalog/hamhf/1570.html
    So it sounds like if you want the added CW filtering, the SG is the way to go.
    I haven't used the 480SAT, but I have used the 570S for several years as a Field Day rig on 20, 40 and 15 meters phone. No complaints :)
  3. KA4EET
    KA4EET Ham Member QRZ Page
    I have the TS 570S and have used it many times on 6 meters. I bought this rig used two years ago for $650. I will sell it when I buy my new TS 590S. All around great radio. I have made decent 6 meter contacts using my 17 meter rotatable dipole (Without a tuner).
  4. K2CLH
    Ok thanks! I couldn't find any reference to the difference but now I see. I don't use CW so it doesn't matter so I think the S would be fine!
  5. NO2A
    NO2A Ham Member QRZ Page
    I have the `570SG. I`ve had it since new and there is one problem I`ve found. It has a noisey front end,even with no antenna connected. Lots of "white noise". The dealer I bought it from agrees with this. I do like the dsp,it`s very effective. The antenna tuner is fine as well. Very user friendly quick memories are handy as well as other front panel controls. The digital filters are great also.
  6. K8JD
    K8JD Ham Member QRZ Page
    You can find a used low band VHF Mortorola Maxtrac or even a CDM750 for a lot less,
    They run 60W, 16 programmable frequencies and a terriffic reciever !
    A lot better than using an HF all mode rig that has 6M FM added as an afterthought
    You will probably have a dedicated vertical antenna for 6M FM anyway, an "allband " HF dipole will not work well for 6M FM use !!!
  7. KG4NEL
    Just from my experiences with HF plus VHF and beyond rigs (IC-746, 706 series, FT-847, etc), the 100W 6M sections do very well with FM...and have SSB capability, something a Maxtrac won't be able to do, and IMHO is where the real fun on six happens :)
  8. W5DOH
    W5DOH Ham Member QRZ Page
    Since the question did not give suitable multiple answers I write here in this post:
    For HF I have a Swan350 and a Alinco DX-70 TH of late I have been using the DX-70 since doing some preventive maintenance on the Swan 350, I like Six Meter and Ten Meter HF mostly sideband for DXing.
    The Alinco is near a Icom 706 without VHF/UHF and the Alinco is all mode.
  9. N0AZZ
    N0AZZ Premium Subscriber QRZ Page
    None of the above! Your best bet would be a Yaesu FT-847 HF-VHF/UHF + satellite rig ever built still one of the best VHF weak signal radios I use mine for SSB/Digital/EME my main HF/6m rig is a FTDX5000MP unmatched.
  10. WD4CHP
    WD4CHP Ham Member QRZ Page
    I dumped Kenwood a long time ago.
    I use an Icom IC-746PRO base and an ICOM IC 706 MKIIG mobile.
