ad: SMHam-1
Heathkit HA-14 Restoration thread
Discussion in '"Boat Anchor" & Classic Equipment' started by WA6MHZ, May 23, 2014.
  1. N2EY
    Build one!
    All you need is a roller coil from an ARC-5 tx and two variables to build an Ultimate Transmatch.
  2. WA6MHZ
    WA6MHZ Subscriber QRZ Page
    Maybe I will find those at the HARTFORD swapmeet
  3. AF6LJ
    AF6LJ Ham Member QRZ Page
    I remember reading that article in QST, that is a rather versatile tuner.
  4. WA6MHZ
    Those will fit in my suitcase and probably wouldn't get the TSA too excited.
  5. WA6MHZ
  6. KD2ACO
    I do that kind of stuff all the time... It does give you more practice with the chop saw!
  7. N2EY
    I remember reading that article when that issue of the magazine came out. I still have it. The circuit works well IF one knows how to adjust it.
    I've built three of them, the first one soon after the article appeared. The one I use now was built in the 1980s - it uses a BC-191/375 coil and two caps that were hamfest finds. Also has built in Monimatch and rig/antenna selectors. It's built in a BC-191/375 tuning-unit case.
    The split-stator 250-per-section cap isn't hard to find. They can be a little pricey because of their obvious use. You can use a dual 100 with a 200 in parallel across the whole thing, too. QST for August 1972, page 32, has a nice implementation which inspired the ones I built. Note the switchable-ratio balun.
    Or, just gang together two 250 pf single units.
ad: Schulman-1
