Hard hack - Embedding a SDR in FT-991A - Need RF designers review
Discussion in 'Radio Circuits, Repair & Performance' started by PY2RAF, Mar 18, 2019.
  1. PY2CP
    PY2CP Ham Member QRZ Page
    you made it!! cheers! de Enrique PY2CP
    PY2RAF likes this.
  2. IZ0ABD
    IZ0ABD Ham Member QRZ Page
    PY2RAF likes this.
  3. PY2RAF
    PY2RAF XML Subscriber QRZ Page
    Enrique querido, thanks for the kind words!!!
    Miss the friend and look forward to meet you again, rather sooner than later.
    Ciao, Francesco!
    Grazie Mille for the kind words. I appreciate, coming from someone with a proper degree :)
    I saw your board, looks great and nifty!! Wish you success! Got curious here on what’s the U1 IC in your board.
    My board borrows the LPF design from G4HUPs (SK) 70 MHz PAT-70 boards, since this is the IF center of my equipment.
    My board is highly specialized for FT-991/A, as you can deduce from the board layout: OE2DOR designed it to fit perfectly in this equipment. And the USB part is also specific for the 991/A radio.
    In the end, this was more a entertaining and fun enterprise. And lots of learning, of course. I have also added a few extra functionalities in the experimental branch. I have ordered the PCB and components yesterday, which PY2UGO will be kindly freighting to me.
    I think that in 3-4 weeks I’ll have the Rev. M deployed with its whistles and bells and will post the outcome here.
    I’m spending this weekend at the country where I’ll be testing and benchmarking against my 40-20 dipole a brand new b-squared engineering T2FD antenna. Will post (in a different thread) my findings.
    Well that’s it
    Thank you very much again
    73s de PY2RAF
    P.S.: I’m starting to document the whole thing at https://github.com/rfrht/FT991A-PAT/wiki
  4. AD5GG
    AD5GG Ham Member QRZ Page
    PY2RAF likes this.
  5. PY2RAF
    Update.
    [tl;dr]
    Went yesterday to Alpha Telecom office and replaced USB2512B with a USB2514B. Unfortunately, it did not work as planned.
    [long post]
    Yvo replaced USB2512B with USB2514B and it was a breeze. The original Audio and CAT ports were identified and functioned normally.
    After having a hard time figuring out how to tap the signals of interest from USB2514, he managed to solder two thin wires to the terminals, that were used to feed to a USB cable, straight to the SDR.
    Here is the bus enumeration sequence.
    Dectected USB2514 hub
    Jun 15 16:00:04 rf kernel: usb 3-3: new high-speed USB device number 10 using xhci_hcd
    Jun 15 16:00:04 rf kernel: usb 3-3: New USB device found, idVendor=0424, idProduct=2514
    Jun 15 16:00:04 rf kernel: usb 3-3: New USB device strings: Mfr=0, Product=0, SerialNumber=0
    Jun 15 16:00:04 rf kernel: hub 3-3:1.0: USB hub found
    Jun 15 16:00:04 rf kernel: hub 3-3:1.0: 4 ports detected
    Dectected the CAT interface
    Jun 15 16:00:05 rf kernel: usb 3-3.1: new full-speed USB device number 11 using xhci_hcd
    Jun 15 16:00:05 rf kernel: usb 3-3.1: New USB device found, idVendor=10c4, idProduct=ea70
    Jun 15 16:00:05 rf kernel: usb 3-3.1: New USB device strings: Mfr=1, Product=2, SerialNumber=5
    Jun 15 16:00:05 rf kernel: usb 3-3.1: Product: CP2105 Dual USB to UART Bridge Controller
    Jun 15 16:00:05 rf kernel: usb 3-3.1: Manufacturer: Silicon Labs
    Jun 15 16:00:05 rf kernel: usb 3-3.1: SerialNumber: 009FF28C
    Jun 15 16:00:05 rf mtp-probe: checking bus 3, device 11: "/sys/devices/pci0000:00/0000:00:14.0/usb3/3-3/3-3.1"
    Jun 15 16:00:05 rf mtp-probe: bus: 3, device: 11 was not an MTP device
    Jun 15 16:00:05 rf kernel: usbcore: registered new interface driver cp210x
    Jun 15 16:00:05 rf kernel: usbserial: USB Serial support registered for cp210x
    Jun 15 16:00:05 rf kernel: cp210x 3-3.1:1.0: cp210x converter detected
    Jun 15 16:00:05 rf kernel: usb 3-3.1: cp210x converter now attached to ttyUSB0
    Jun 15 16:00:05 rf kernel: cp210x 3-3.1:1.1: cp210x converter detected
    Jun 15 16:00:05 rf kernel: usb 3-3.1: cp210x converter now attached to ttyUSB1
    Detected the audio interface
    Jun 15 16:00:05 rf kernel: usb 3-3.2: new full-speed USB device number 12 using xhci_hcd
    Jun 15 16:00:05 rf kernel: usb 3-3.2: New USB device found, idVendor=08bb, idProduct=29b3
    Jun 15 16:00:05 rf kernel: usb 3-3.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
    Jun 15 16:00:05 rf kernel: usb 3-3.2: Product: USB Audio CODEC
    Jun 15 16:00:05 rf kernel: usb 3-3.2: Manufacturer: Burr-Brown from TI
    Jun 15 16:00:05 rf kernel: input: Burr-Brown from TI USB Audio CODEC as /devices/pci0000:00/0000:00:14.0/usb3/3-3/3-3.2/3-3.2:1.3/input/input19
    Jun 15 16:00:05 rf kernel: hid-generic 0003:08BB:29B3.0004: input,hidraw3: USB HID v1.00 Device [Burr-Brown from TI USB Audio CODEC ] on usb-0000:00:14.0-3.2/input3
    Jun 15 16:00:05 rf mtp-probe: checking bus 3, device 12: "/sys/devices/pci0000:00/0000:00:14.0/usb3/3-3/3-3.2"
    Jun 15 16:00:05 rf mtp-probe: bus: 3, device: 12 was not an MTP device
    Jun 15 16:00:05 rf kernel: usbcore: registered new interface driver snd-usb-audio
    Detected but failed to enumerate the SDR device
    Jun 15 16:00:05 rf kernel: usb 3-3.3: new full-speed USB device number 13 using xhci_hcd
    Jun 15 16:00:05 rf kernel: usb 3-3.3: device descriptor read/64, error -32
    Jun 15 16:00:05 rf kernel: usb 3-3.3: new full-speed USB device number 14 using xhci_hcd
    Jun 15 16:00:06 rf kernel: usb 3-3.3: device descriptor read/64, error -32
    Jun 15 16:00:06 rf kernel: usb 3-3.3: new full-speed USB device number 15 using xhci_hcd
    Jun 15 16:00:06 rf kernel: usb 3-3.3: Device not responding to setup address.
    Jun 15 16:00:06 rf kernel: usb 3-3.3: device not accepting address 15, error -71
    Jun 15 16:00:06 rf kernel: usb 3-3.3: new full-speed USB device number 16 using xhci_hcd
    Jun 15 16:00:07 rf kernel: usb 3-3.3: device not accepting address 16, error -71
    Jun 15 16:00:07 rf kernel: usb 3-3-port3: unable to enumerate USB device
    After checking USB2514 design checklist, I have found no special requirement for capacitors or resistors - It should be wired directly to the port, so no breaking news.
    I have also checked for a few possible hypothesis:
    * Bad USB host - Ruled out, have the same behaviour in both Windows and Linux
    * Bad PC negotiation - Ruled out, as the other devices were correctly detected
    * Voltage ripple: Ruled out. There were some voltage variation when plugging in the USB hub. As a counter-measure, I bridged the 13.8V straight to the ENABLE in the power regulator, so it would be on all the time, avoiding the ripples. Issue persisted.
    * Voltage sag: Might be possible. See below thoughts.
    * Design issue: ruled out, after revisiting the USB hub Datasheet and Design checklist, everything seem to be sound and good.
    * Bad USB hub config: Slim chances; There are some "Strap Configs" for this USB hub, but they seem to be more about overcurrent and presenting to the computer as permanently attach or removable devices.
    * Bad wiring: Checked and re-checked and everything seem to be in good order.
    * Bad port: There's a slim chance that Port 3 is just plain bad/damaged. Might be worth a shot trying Port 4.
    Now, a few words about linear power regulators.
    When powering the SDR from the board, the 13.8V -> 9V regulator gets REAL HOT. _Very_ hot. While the 13.8 - 9V regulator datasheet specifies that Tjunction for this regulator is 150 Celsius (and temperature was definitely below that) and a few Ohm law calculation, I'm afraid that while the SDR during operation draws approx. 310 mA in 5 V during peak operation, the efficiency, the PCB substrate and the heat dissipation might put everything at a very tight power / heat dissipation budget. This has to be better evaluated and thought of.
    For what is worth, the circuit was drawing 160 mA from the 13.8V line when powering the SDR.
    As of now, I have reverted to the original setup (just took the opportunity and better wrapped the SDR and added, used a beefier USB cable and added a good grounding to the board, everything got a lot cleaner) and I still have that hateful USB cable coming out of the radio.
    Let's see how that develops.
    My 73s,
    PY2RAF.
  6. PY2RAF
    Have not thrown the towel yet.
    While I don't do a final round of tests involving the USB hub, I have released Revision N - In a different github branch, named "NoUSB".
    In this branch, this is a panadapter board without USB stuff, but with a few features, namely:
    1. IF TAP
    RATIONALE: You can select to tap or not tap the signal from your SDR. By default, the Panadapter board will not consume any IF signal if you don't explicitly enable it.
    STATES:
    * Isolate the SDR (default) - No signal is consumed from the radio and the SDR is left grounded
    * Tapping IF signal - Feed the signal to the next stage in the Panadapter board.
    2. BAND-PASS FILTER
    RATIONALE: Ability to choose to either a filtered signal (with insertion loss and reduced bandwidth) or the whole IF signal
    STATES:
    * Pass-Through (default) - The IF signal is forwarded untouched and unaltered ahead to the next stage. There is no insertion loss and the signal features the entire IF bandwidth.
    * Band-Pass - The signal is filtered at the center of the IF frequency (69.450 MHz), giving 3 MHz of bandwidth, filtering strong signals that might generate image artefacts in the SDR. The RTL-SDR optimum bandwidth is 2.4 MHz.
    3. HIGH IMPEDANCE AMPLIFIER
    RATIONALE: Ability to use the high impedance amplifier + low noise amplifier or choose to tap the IF signal unaltered
    STATES:
    * Amplified (default) - The IF signal enters a JFET source follower to present a high impedance to the IF filter, minimising any loading on the main signal path of the radio. This is fed in a 2SC5086 as an emitter follower to amplify the signal.
    * Pass-Through - The signal is tapped from the IF signal and forwarded straight out to the SDR port.
    A few more changes:
    * Got rid of the G4HUP LPF. Reasoning: Found it of no use, since it cuts the signal 24 MHz above the IF center frequency. The selectable BPF suits better (fingers crossed).
    * Moved regulators and signal pads to the upper board side (access & heat dissipation)
    * A slimmer BOM (more than 10 components removed)
    Board ordered, around a month to arrive, will let you all know the outcome.
    73s,
    - Rodrigo.
  7. PY2RAF
    IT'S ALIVE!!!!!!!! \o/
    And it WORKS!!!
    Everything coming down through a single USB cable!!!! :D
    Video here.
    It was a missing pair of 22 ohm resistors on the USB line. And that was it!
    The documentation and test results are all in the Project's Wiki.
    Now everything coming down from the Radio's USB port, in tandem; the Audio, CAT and SDR:
    Everything working nicely and great! And fortunately this is no longer the case here:
    or
    MANY THANKS to Everyone that helped this to come true!
    73!!!
    KC9ONY likes this.
  8. KC9ONY
    KC9ONY Ham Member QRZ Page
    Congratulations Rodrigo! Persistence pays off!
    Like the documentation as well. :cool:
    PY2RAF likes this.
