ad: M2Ant-1
Hard Disk Crash, My First and it Sucks..............
Discussion in 'Computers, Hardware, and Operating Systems' started by K2WH, May 8, 2019.
  1. K2WH
    K2WH Premium Subscriber Volunteer Moderator QRZ Page
    Yes, it does and I am slowly slogging through the muddle of info that is there (I had a backup), and stuff that is no longer than.
    Downloading drivers that don't work and software that is missing and was supposed to be on the backup but it is not.
    Trying to get FT-8 back up, but the drivers although installed, do not seem to work.
    I have no sound even though ----------------- oh forget it.
  2. W7UUU
    W7UUU QRZ Lifetime Member #133 Administrator Volunteer Moderator Platinum Subscriber Life Member QRZ Page
    Ugh :(
    I’ve been there and it really does suck
    Good luck
    Dave
    W7UUU
    KK4NSF likes this.
  3. W6RZ
    W6RZ Premium Subscriber QRZ Page
    Unfortunately, SMART (Self-Monitoring Analysis and Reporting Technology) isn't well supported on Windows. On Linux, it can often warn you when a drive is just starting to fail (long before it crashes).
    KF5RRF and KK4NSF like this.
  4. AF9US
    AF9US Premium Subscriber QRZ Page
    K2WH:
    Frustration and defeat....
    After experiencing a PC crash, due to the age of the HD, rather than replace the HD then restore, I decided to rebuild. My PC that crashed about 10 years ago, then it was already outdated - hardware wise. I always wanted to build a PC, that turned out to be the opportune time!
    New motherboard with up-to-date hardware, new SSD, and, later, a new power supply and case; the project was finished. Software wise, I downloaded software I used on the crashed PC. All worked very well, while more expensive than a replacement HD, building of the PC resulted in far less headaches, frustration, aggravation, almost uncontrollable cursing....
    If inclined, give building a PC from components a try.
    Satisfaction far out weighs the agony of a PC crash,
    Bernie, AF9US
    KK4NSF and K6CLS like this.
  5. WF7A
    WF7A Subscriber QRZ Page
    Not to rub salt in the wound, but how often did you back up and/or create restore points in your computer? If you're going that far back where drivers aren't working, then I suspect you didn't back-up often enough; for your limited use, a weekly backup should be made.
    Add to that missing drivers that should've been backed-up, well...you should try giving a better backup program a try so everything is backed-up.
  6. KK4NSF
    KK4NSF Ham Member QRZ Page
    I think many of us have been through that... and it's a pain in the backside, to say the very least. If the HDD is really dead, or missing sectors, then recovery is going to be painful.
    Going forward, think: RAID 5. After my last HDD crash, I installed it on my upgraded machine, and have not lost a single byte of data since. Regular backups to an external storage are not a bad idea either.
    One thing you might be overlooking are the Motherboard Chipset Drivers. If you have no sound, that's the first place I'd look.
  7. AA7QQ
    AA7QQ Ham Member QRZ Page
    Most MS backups just keep your data, not OS & software. A clone actually allows you to just plug the backup drive in & go (With some Startup repair).
    Ed
  8. N3AT
    N3AT Ham Member QRZ Page
    Acronis True Image has served me well for full system backups.
    KD4MOJ and K2WH like this.
  9. WF7A
    I use Carbon Cloner (for the Mac)--been using it for years and it has great support.
  10. KA9JLM
    If the motherboard supports SMART it should not mater what OS is on the system.
    It runs a test before any OS has booted.
    I use Win98 SE and Ghost to mirror disks. The disk size limitation is the only draw back, But I do not keep all of my eggs in one basket.
    Old school works and is reliable.
    Most crashed drives can be recovered with a little work. Just to get drivers back may not be worth it.
