Ham Radio - An end fed half wave antenna with built in counterpoise. (Experimental)
Discussion in 'Amateur Radio News' started by KB7TBT, Aug 28, 2019.
  1. KB7TBT
    KB7TBT Ham Member QRZ Page
    N9DWE likes this.
  2. W9ZD
    W9ZD Subscriber QRZ Page
    Are you sure that the coax shield is not the counterpoise?
    VA7JMP and K3RW like this.
  3. W1YW
    The coax WILL radiate. But---if choked properly the counterpoise does a phase cancellation on that electrical length, kinda like a J pole.
    Basically this is a method to end-feed the antenna, normally not easy because the voltage max lies at the ends, and matching it is lossy and not easy. Here the 'end' is really an OCD point electrically. The antenna is designed as a convenience to stop the drooping coax such as you see on a dipole.
    These designs have been around for a while. Nice to see it discussed here.
    KQ6XA likes this.
  4. K0UO
    K0UO Subscriber QRZ Page
    how do you get a 49:1 match?? how much po
    How do you get a 49:1 match to take much power, will how much power will it take? I'm inpresed it will take 40 watts
    I run QRO
    AF4RK, KQ6XA and W1YW like this.
  5. K6GB
    K6GB XML Subscriber QRZ Page
    Version of that in an RSGB antenna book 50' long with 25' counterpoise made with speaker wire and a toroid wrapped at the end, the speakerwire goes straight into a tuner, covers 40-10, a half size covers 20-6. They show it as a vertical and it has pretty low radiation angle, they also show a dual phased array, quick and dirty, a roll of speaker wire 2 toroids and a balun.
    W1YW likes this.
  6. W7QQQ
    W7QQQ Ham Member QRZ Page
    Match with an LC resonant tank circuit between antenna and counterpoise. Couple the coax feed with a one or two turn link to L.
    Very efficient.
    MM0XXW and K0UO like this.
  7. K0UO
    Just Hit that 49:1 setup made of small speaker wire and a small toroid with 1.5 kilowatts and see what happens !!!!
    KQ6XA likes this.
  8. K6GB
    Better be a big donut and very thick wire, hi!
    K0UO likes this.
  9. K6GB
    Design attributed to K9ESE, phased version to M3KXZ. The book is RSGB Successful Wire Antennas.
    W1YW likes this.
  10. W7QQQ
    For QRO, I've put 1.5 KW into the matching network I described above. No problem. Use air wound coil and capacitor with sufficient spacing.
    You can make the one or two turn link with a variable capacitor in series so you don't have to vary the spacing of the link coil.
    1 to 1 swr.
    The counterpoise doesn't have to be fancy twin lead... just hang or lay out a few feet of wire... 3 or 4 ft.
