Hallicrafters S-120 hum
Discussion in '"Boat Anchor" & Classic Equipment' started by K1OIK, Feb 13, 2018.
  1. K6GB
    K6GB XML Subscriber QRZ Page
    As a former owner of an S-120, 14th birthday, so it was almost new. It always hummed, and didn't hear worth a damn above 20m.
  2. W9GB
    LOOK at botton of schematic for AC filament string.
    As noted earlier, four (4) tube filaments and two (2) #47 dial lamps (6.3V) wired in series.
    Voltage on that AC filament string: 50+12+12+12+6.3+6.3 = 98.6 Volts.
    Remaining Voltage (~22 Volts) used by R22, Globar resistor.
    You could consider higher voltage bayonet dial lamps, to replace the #47.
  3. KA9JLM
    Don't get shocked Bert. :eek:
  4. K1OIK
    K1OIK Platinum Subscriber Platinum Subscriber QRZ Page
    I use an isolation transformer.
  5. SM0AOM
    SM0AOM Ham Member QRZ Page
    AC/DC HF receivers with mixer-oscillator stages using "hot cathodes" (in the RF sense) are notorious for modulation hum
    caused by capacitive coupling or leakage between the filament and the cathode.
    When you have ruled out any power supply filtering issues such as dried out electrolytics,
    I would suggest replacing the 12BE6.
    73/
    Karl-Arne
    SM0AOM
  6. KP4SX
    KP4SX Subscriber QRZ Page
    Oops. Sri.
  7. WN1MB
    WN1MB Ham Member QRZ Page
    Take all three sections of C31 out of circuit - then wire in caps of known integrity. That's the better way to rule out the electrolytic.
  8. WN1MB
    The 120VAC out of the isolation transformer can be as lethal as the 120VAC feeding it...
  9. K1OIK
    But when I hook up a scope I won't see sparks fly out of the ground connection.
  10. K1OIK
    You think the capacitors are shorted?
