ad: TinyPaddle-1
GREAT ! Call, name etc.. on Display of TYT MD2017 and Retevis RT-82 !
Discussion in 'General Announcements' started by IW2BSF, Jul 12, 2017.
  1. IW2BSF
    IW2BSF Ham Member QRZ Page
    NOW THE OVER 65.000 OM OF THE WW IN THE TYT MD-2017 and RETEVIS RT-82
    A great notice , with the Original Firmware 3.33 you can upload CSV files up to 100,000 contractions and then you can see them with a window like the MD380Tools !
    Select import and write (see down the photo ! )
    For save the data base into the radio select "Read" and "Export"
    If say an error EXCELL :
    in the MENU in the top:
    -> [Program]
    --> [Write Contacts]
    open the window Read/Write Contacts and select:
    -> [Import]
    open a window and select *.CSV
    --> [Write]
    PLEASE control if you gìhave the new CPS 1.17 because the old 1.16 chrge only 35.000 +/-
    and not the 100.000 contacts to import the all WW ham-radio (over 65.000 at today ! ).
    The FILE CVS is in download on the Facebook group on the TYT MD-2017 !
    NB Not OVERWRITE, in the radio you have boths your contacts and the CSV.. always aviable too!
    The codeplug in the Folder "Digital Contact" where write the TG, and with the info describe up you can charge the CSV
    Now like the old MD-380 and Rtevis RT-3 you in the new radios have all the data on the display ( NOT for the privacy for the eruopean ham-radio that you see only the Call and name ! ).
    NOTE:
    Export your contacts as csv file. Open your new contacts list in notepad, select all and copy it. Open your radio saved csv file and paste at the end of the last contact. Save file then import back to radio. Because your original contacts are first in the list, it does not mess up all your channels
    I have successfully created a CSV file as you described above thank you. I have the new cps software. I have the new firmware with contact CSV enabled.
    When I upload it to the cps useing the import function I can only see 10,000 contacts and they only show the ID number and not the persons name. Although when creating the CSV file all the names are clearly there. Thanks for the reply
    When you fist look at a blank csv file there is a line there that tells you how to form each line properly
    73 de IW2BSF - Rudy
  2. IW2BSF
    hi.... i read for any ham-radio this not work or say errors ...... here the solutions :
    A VERY GOOD GUIDE TO DO:
    ok i try but After import It will not go beyond 10,000 contacts !!
    Here's how to do it. It's not obvious, but follow the instructions and it works. I have 64,000 contacts in mine.
    http://www.alisterchapman.com/ham-radio/uk-dmr-codeplugs-for-the-md380-and-tyt-md2017/
    Note that the layout of the .csv file needed for the CSV function is different to the layout used in the CPS contacts list.
    It's pretty easy really. Just update the firmware with the right version and then use the right version of the CPS to upload the csv file directly to the radio.
    ok, what is the right version ?
    TYT-2017 UV-(CSV)V3.33 and UV-(CSV-GPS)V3.33 these are different to the regular V3.33 versions.
    Will this change the info I already have in it
    No. It should leave any existing code plug as is. The csv database is saved in a separate area. It's always wise however to read your code plug from the radio and save it before proceeding, just in case.
    I tried your guide Alister Chapman everything went exactly as you said, but when I read my radio, i still only have my contacts, not the full database
    PROBLEMS :
    1) I tried your guide Alister Chapman everything went exactly as you said, but when I read my radio, i still only have my contacts, not the full database
    Have you turned on the CSV contacts in the utilities menu?
    If you go to the contacts menu can you see the CSV contacts?
    I see them now, but my csv file must be set up wrong, all I see are "2"'s
    Use the .csv file on my website. It was created today so should be up to date and it has the entire DMR database. The formatting is different to the .csv files used by the main contacts list as it allows you to save names, nicknames, cities and countries as well as the ID numbers.
    I tried this method but the CPS fails to import the csv database with the error 'Excel fail'
    Did you format the fields in the excel file? Only 4 columns of data
    2) I can not import the csv database. There is always the error message Exel failt.
    You have to have microsoft Excel installed on the computer ?
    BEWARE !!!!
    a) After you set this data base into the radio you lost the RECORD MODE !
    (The firmware that allows 100,000 contacts removes the ability to record a QSO (uses same memory space)
    b) You also need Microsoft Excel installed, I have the free LibreOffice installed and the import of csv database doesn't work, it caborts with Excel fail
    73 de IW2BSF - Rudy
  3. IW2BSF
  4. IW2BSF
    NOTE: this add to have 100.000 contacts used a SPECIAL FW ! beware !
    if you used this FW.... you lost the record mode in your radio .
  5. KD2NFC
    KD2NFC Ham Member QRZ Page
    Hi I did this on my MD UV380, works great but when I transmit I get ID error because it cant ID the talkgroup? Have you see this issue, is there a work around.
  6. IW2BSF
    HI..... now all the TYT MD-380 and Retevis RT-3 have a BIG problems for the internal little memory !
    now the WW amateur radio database is over 120.000 calls !
    the solution is used the NEW TyeraFlashTool selected the ToolZ !
    in my web site there is a simply and short guide to installed this .
    73 de IW2BSF Rudy
  7. KD2NFC
    Rudy, thanks for the info. I dont mind the 100k contacts I have but I will try the ToolZ. is that compatible with the UV380? mine is dual band where this firmware looks like it for the monoband MD380/390
  8. IW2BSF
    sorry, i not say this.... i think is ONLY for the old MD380/390 and retevis Rt3 ..... 73
ad: Flexradio-1
