FTM-350AR APRS
Discussion in 'Working Different Modes' started by K3WDT, Apr 7, 2012.
  1. K3WDT
    K3WDT Ham Member QRZ Page
    I have a FTM-350AR in my truck for mobile use. I have a macbook(with the ability to run windows xp) and a garmin nuvi 350 gps. what setup can i use to run APRS? i would be willing to purchase the yaesu gps unit if i have to.
  2. KX0Z
    KX0Z Ham Member QRZ Page
    My friend has the FTM-350AR and uses APRS with the Yaesu gps unit. It's pretty much plug/play. Install the gps and activate the APRS function. Keep in mind during APRS operation it ties up 1 side of the radio..
  3. K0RGR
    The 350AR has a packet radio port. I wanted to read more on this, since I believe the 350R did not have this capability. I think you can use the packet port to gain access to the TNC, hopefully in KISS mode, which some of the popular APRS programs out for the PC will support. Unfortunately, I could not download the AR manual.
    XASTIR is an open source APRS program that runs on OSX, among other places. You should be able to get your GPS talking to the PC, running XASTIR, talking to the packet port on the 350AR.
    You should get the GPS for the 350AR - it will be much easier to use as a self-contained unit as opposed to dragging the PC around everywhere. Use the PC when you need to display other stations around you.
  4. K3WDT
    do you think that the built in unit will work sitting just below the factory radio in my truck? also any suggestions for a 8pin din to USB cable? i cannot find one anywhere
  5. KX0Z
    If you purchase the Yaesu programming software it will come with the cable..
  6. K3WDT
    does anyone think that the built in gps unit will get satellite signal sitting just below the factory installed radio in my truck?
ad: vanity
