FT8 on a ICOM 706MK11G
Discussion in 'Working Different Modes' started by KD8LLS, Feb 11, 2019.
  1. KD8LLS
    KD8LLS Premium Subscriber QRZ Page
    I have been trying to run FT8 on My ICOM706MK11G and it dosn't seem to have any RF going out to the antena I'm using the WSJT-X program with a signalink interface and a G5RV all band antenna
  2. WB5WPA
    WB5WPA Ham Member QRZ Page
    Should work; I use a MkII all the time ...
    What kind of I/F do you use?
    Use a Signalink here.
  3. W5DXP
    W5DXP Ham Member QRZ Page
    Sounds like you are not getting any audio into the 706. You can use headphones to track down where those tones are getting derailed.
  4. WB5WPA
    Ah ... I see you are using a Signalink ... is the SL getting enough audio to trigger the SL's VOX xmit keying circuit?
    From there, the proper programming 'jumper' inside the SL is required, as well as cable. I've noticed on my Mk2 that audio coming in the rear panel jack can also be heard on the speaker of the Mk2 ... can you hear audio coming out the radio spk if the SL is not keying the radio?
  5. KD8LLS
    The signalink and the radio both key up but the cross needles on the SWR/Watt meter (MFJ Deluxe versa tuner) are not moving also it will transmit sometimes when the power is all the way down thanks
  6. KF4ZGZ
    KF4ZGZ Ham Member QRZ Page
    Try upping the power and mic gain settings on the 706 a click or two at a time to see if anything happens.
    On my MKII ..... the normal "turn it all down" mentality just simply won't work.
  7. WB5WPA
    The 706 Mk2G has a power out indicator too. It's under the "M" menu soft-key I think. What does it show?
    Your I/F (interface) cable to the radio or jumper in the SL is wrong or bad, if the rig keys up it means AUDIO is getting to the SL from the PC/laptop via the USB serial bus b/c the SL uses an internal VOX (voice operated relay to key the radio) that is actuated when audio "pours out" of the PC via the USB serial bus to the SL.
    You have adjusted the "TX" knob on the SL? That controls the audio level directly to the 706.
  8. KD8LLS
    thanks for the help
  9. KD8LLS
    thanks for the help
