ad: portazero-1
Exothermic Ground Rod
Discussion in 'Amateur Radio News' started by N5HZR, Sep 1, 2018.
  1. WA7PRC
    WA7PRC Ham Member QRZ Page
    Several exothermic welds were used in my tower's buried ground connections:
    [​IMG][​IMG]
    click for bigly image(s)
    N5HZR and K8MHZ like this.
  2. WD0BCT
    WD0BCT Ham Member QRZ Page
    That was exactly what I was referring to. It is pretty clear..."Connections depending on solder shall not be used." That was my point...and the topic of this thread is exothermic connections to ground rods. Please reread my post.
    Regarding compression fittings for use on ground connections...I recall when such fittings were first approved and Burndy and other suppliers demonstrated them to our electrical department. Most of the old timers didn't care for the compression fittings. I was a young buck and felt...if they are approved someone must have tested them!
    None of the engineering firms I worked for used soldered connections for a ground connection whether it was within a ground grid or connection of the grounded conductor to the electrode. The reason was that a soldered connection and high heat did not work to well for the soldered connection.
    Oh..and FYI MHZ my first introduction to the NEC was in 1960..but the approved revision was earlier than that. I was a freshman in a technical HS and little did I know I would be involved with that document for my entire professional career!
    N5HZR and KX4O like this.
  3. K8MHZ
    K8MHZ Ham Member QRZ Page
    I wasn't contesting you, just quoting some NEC stuff about where solder can and cannot be used.
  4. K8MHZ
    This is what is used most of the time. No special tools required. I have never seen one 'blow up' or fail yet.
  5. WD0BCT
    Sorry about the confusion...but you quoted me and I was not clear if you were disagreeing or agreeing.
  6. K8MHZ
    I suppose I could have done a better job with that post. I just grabbed my oldest NEC and posted what I thought applied, I didn't mean to imply you were doing ground rods wrong.
  7. KV6O
    KV6O Ham Member QRZ Page
    I have. These are not allowed in R56 sites - the resistance can easily degrade over time as this is not a gas tight connection.
    N5HZR, KX4O and K8MHZ like this.
  8. K8MHZ
    I will be the first to admit that the NEC is a bare minimum set of standards. R56 is much stricter (and better) but I know of no where that has adopted it into law like the NEC. For those interested, here is a link to R56.
    https://sites.auburn.edu/admin/faci...ject Documents/1/Motorola_R56_2005_manual.pdf
  9. WB8LBZ/SK2023
    WB8LBZ/SK2023 Ham Member QRZ Page
    Nice video. Even with the fail the recovery was good and that is all that matters.
    73, Larry WB8LBZ
    El Paso, TX
    KX4O and N5HZR like this.
  10. W2WDX
    W2WDX Premium Subscriber QRZ Page
    Argh! NEC is not law. It's an accepted standard, and one adopted by the insurance underwriters in the US. That is the reason why the NEC is relevant to this discussion and in general. Insurance. R56 is a stricter standard, and is so due to the fact the NEC does not consider frequency and impedance, only the safety requirement for power systems at 60Hz. When considering RF it is not simply a matter of low resistance (which is fine for power systems); frequency and impedance is equally important. If impedance (not simple ohmic resistance) is high enough, such a ground connection will be "invisible" to some RF energy, making it useless for any RF grounding. Recent studies have also shown lightning can more often than not have a given percentage of its total energy present itself at frequencies as high as the low-end of VHF.
    Solder connections fail long before the wire. The issue is heat. The various connection methods mentioned are not the same. A copper wire will withstand much more heat than any solder connection, same for any brazing method. And anything other than perfect soldering/brazing means higher resistance (translating to faster heating) compared to exothermic connections. Also, brazing and soldering can have gas and liquid ingress or trapped, which will cause corrosion and higher resistance as a result over time. Neither soldering or brazing are like exothermic bonding, which uses heat to fuse two metal objects together by melting them with similar intervening joining metal(s) added to the process. Welding is similar, yet not quite the same. Brazing relies on the intervening metal for the bond. Soldering does not melt the joined metals at all and is not even a molecular bond of any kind. It's basically a conductive metal version of hot glue. Lightning will simply melt solder in micro-seconds and spit it out around your yard, long before the energy of the strike has dissipated.
    Mechanical connections can be used but only in specified connection points, and never on the common electrode part of the circuit.
    KX4O, N5HZR and W1YW like this.
  11. W1YW
    "Ther-MITE!"--Hayduke
    NC7U and N5HZR like this.
  12. K8MHZ
    The NEC itself is not law, that is correct. However, it IS the law in places that have adopted it as such, and those places are a majority of not only the US but other countries as well. Here in Michigan, our electrical law is called the Michigan Electrical Code, but it references about 90 percent of the NEC as adopted law.
    The gist of your post was excellent, however. Especially the part about the connections.
    N5HZR likes this.
  13. W2WDX
    Yeah it's a funny thing. Insurance companies, especially the big ones, basically ignore local ordinances that are not exclusively adopting the NEC in full. They will apply the NEC to the fullest extent on claims in areas not using it as local codification. Unfortunately people think the are covered if they adhere to local codes, and most times they truly are not. Here the NEC is referenced specifically as the code in it's entirety, with additions. (For instance, in my township wires leading into the home as antennas or feedlines must be 12ga, not 14ga as in the NEC. Who knows why, but it exceeds NEC standards regardless).
    This explains also why (along with other factors) insurance premiums are cheaper in certain areas; the insurance companies know they can argue that any installation, whether power based or a station, is not in compliance with the NEC. This mean they pay-out less on claims in regions that do not use the NEC for their local codification, and therefore the insurers can afford to offer more "competitive" premiums.
    N5HZR likes this.
  14. K5JDW
    K5JDW Ham Member QRZ Page
    Really enjoyed the process and the "if first you don't succeed" approach, with no cuts, as sometimes is true with a real process especially out in the field. And of course all us engineers may be analyzing deep down in our left Brain the plusses and minuses of what we are seeing while all the time thinking this looks like almost as much fun as playing with Thermite !! Which it may be ??
    Thanks Mark and Ed
    N5HZR likes this.
  15. N8OX
    N8OX Premium Subscriber QRZ Page
ad: CQMM-1
