ad: Amateur-1
Echolink + eQSO
Discussion in 'Ham Radio Discussions' started by RC3C, Jul 17, 2002.
  1. RC3C
    RC3C XML Subscriber QRZ Page
    Hi all
    I wanna run EchoLink and eQSO together on my home PC. I use only eQSO RR3DA Vhf Repeater - rv3dhc.ttk.ru/rr3da
    And use the PTT standart diagramme (it is COM-port diagramme).
    How to run both programmes here??  [​IMG]
  2. K1ZC
    K1ZC Ham Member QRZ Page
    Most sound cards can only handle one application at a time. If you don't have a soundcard specifically designed to handle multiple sessions, you will have to run one program at a time or upgrade your computer.
  3. RC3C
    I can't use two prorammes on my PC together in cas ther echolink said that the port is in use already and can't listen for it :-(
    How can I run them together use normal PPT diagramm on both COM-ports on one PC?
    Anthony
  4. N7CPC
    N7CPC Ham Member QRZ Page
    Most PC's have an extra sound card slot. If you have the processer for it you should then be able to run both apps.
    Depending on the cards, you might need a lot of processer. Some require lots of RAM. Consider a low end card for the second slot.
    73 de Craig........N7CPC
