Echolink DTMF- computer not reading
Discussion in 'Echolink/IRLP Tech Board' started by W0LYQ, Apr 9, 2012.
  1. W0LYQ
    W0LYQ Ham Member QRZ Page
    I have echolink up and running in SYOP mode and can connect to the test server via the computer- when I press the PTT on the HT there is and indication that showes "SIG", however I cannot access using the 9999 code. Comuter does not read any DTMF code (numbers/etc are not showing up in lower right corner). The DTF settings for SYOP are the default settings (0,2,12,4). Not sure what needs to be adjusted. Any assistance would be greatly appreciated. Thanks/
    Ed Robarge
    W0LYQ
    Leavenworth, KS
  2. KC5FM
    KC5FM Ham Member QRZ Page
    Ed,
    This was addressed on the Echolink users group on Yahoo.
    I'd recommend you join that list.
    Hope that helps.
  3. W0LYQ
    Joined this AM, read several of the posts, but didn't see one that fit my issues. Just not able to get the DTMF code from HT to Computer to bring up, let's say, the test server at 9999. Will keep checking//Thanls
    Ed Robarge W0LYQ
  4. KC2UGV
    KC2UGV Ham Member QRZ Page
    What sound card are you using? If it's a crap soundcard, the DTMF tones get junked up.
  5. KA9JLM
    KA9JLM Premium Subscriber QRZ Page
    You may want to check your Audio Mixer settings to make sure your audio is routed correctly.
    Good luck on your project.
  6. W0LYQ
    I'm using the card that comes with a Sony Vaio i can hear the tones, but they do not show on echolink as "decoded" (accepted/transmitted) yet i can press the PTT and it shows a"SIG" in the right corner. Just the DTMF not making into computer. Will check vol. settings tonight after work//Thanks for your ideas
    Dr Ed Robarge
    W0LYQ
  7. W0LYQ
    Thanks
    Checked my audio all around and cleared up the problem -- thanks for your suggestion
    Ed Robarge
    W0LYQ
  8. KA9JLM
    Good deal Ed, Nice that you got it working. Sometimes we overlook the simple problems.
    But we always make it work.
