Echolink disconects me after 1 minute
Discussion in 'Echolink/IRLP Tech Board' started by SV2EVS, May 12, 2019.
  1. SV2EVS
    SV2EVS Ham Member QRZ Page
    Hi all,
    i just did a setup of an echolink node, with an old netbook, echolink and its set on a simplex freq.
    Problem is when i connect to the node, it disconects me after 1 minute, either from wifi or 3g.
    I can't figure out what it is, i can't change to a public proxy (no list shown)...
    Any hints ?
  2. KA9JLM
    Sounds like your Firewall may be blocking ports.
    You need to add Echolink.exe to the exception list.
    KB3VWG likes this.
  3. W7CJD
    W7CJD Ham Member QRZ Page
    I put Echolink on my PC, I found the instructions for my router in Echolink FAQ ..so there is your firewall, perhaps your antivirus packaged firewall, and your router.
  4. SV2EVS
    Ports on the router are open. If i connect my node to some other node it stays connected. If i use my phone, as i said above it drops the connection. EITHER WIFI OR 3G ! So its not the firewall..netbook is running windows xp, firewall is off.
  5. SV2EVS
    i changed my cellphone's echolink connection to public proxy (settings) and it seems to stay connected more than a minute...can anyone explain ?
  6. KA9JLM
    Your ISP is blocking UDP ports.
    KB3VWG likes this.
  7. SV2EVS
    My isp ? They can do that ? Over 3g ?
  8. SV2EVS
    Is there a way to see if my wifi doens't transmit all the packets when echolink is online ?
    Using an old LG-X110 netbook...
  9. KA9JLM
    Yes. They do it. Many wireless ISPs do.
    T-mobile does for sure. I have to use a proxy server. I set my own up using java and the echolink .jar file.
    Your WiFi can not send packets that it does not get to relay.
    What ISP do you use ?
    KB3VWG likes this.
  10. SV2EVS
    ok, i see...so the best way is to test it on wifi from another point other than my own network...
