Dumb q - icom 706mkiig molex socket (on unit) replacement’s
Discussion in 'Radio Circuits, Repair & Performance' started by KK6VQK, Oct 1, 2019.
  1. KK6VQK
    KK6VQK Ham Member QRZ Page
    hi!
    I'm looking for a replacement molex socket for the 706mkiig. The previous owner broke off the tab on the socket so power cables don't actually stay plugged in.
    What should I be searching for?
    Thanks!
    -adrian
    (kk6vqk)
  2. ND6M
    ND6M Ham Member QRZ Page
    I always call them Molex connectors too, but, I think they are actually metric.
    the MFJ plug 5535 should fit,.... $20.:rolleyes:
    I had similar issue with the plug on my PRO III, I just unscrewed the two leads from the board, and ran new wires thru a rubber boot that fit the chassis hole, and then installed Anderson PP connectors.
    FWIW, I also replaced that junk ICOM fuse holder too. They have a habit of developing a voltage drop.
    Oh,..... I just reread your post, are you looking for the female end that mounts to the rear panel?
    Whatever you do, be real careful when removing the chassis mounted connector, it is REAL close to other ckt brd components inside the enclosure.
    Good Luck
