DM780 Waterfall display
Discussion in 'Ham Radio Deluxe - HRD' started by N2LK, Feb 11, 2010.
  1. N2LK
    N2LK XML Subscriber QRZ Page
    I bought a new PC for the shack which is fast and runs HRD+DM780 V.5 quite well...I am moving from years of using MixWin to DM780 and have 2 questions for you experts:
    1. Waterfall resolution
    I am so used to the MixWin waterfall which appears to have, for lack of a better phrase, clearer "resolution". Below are 2 quick digi photo's I hope shows what I mean.
    Any tips for adjusting the waterfall display to get a cleaner resolution of signals?
    2. Mouse Tuning
    Mostly for rtty operation, Mixwin has nice mouse wheel tuning..I dont think DM780 has this, does it?
    Thanks in advance for any advise and 73!
  2. VE3FMC
    VE3FMC XML Subscriber QRZ Page
    Your waterfall looks about right for DM780. To be honest I did not notice a lot of difference as far as the brilliance and clarity between it an your other software's waterfall in the pictures you posted.
    I use a different color on my DM780 waterfall as I find that blue color brutal!;)
    Go to Program Options in DM780.
    Scroll down the options list on the left side of the box.
    Go to Waterfall and click on it.
    Then click on color.
    Check off Select From List
    Then put your mouse on the colors listed and start scrolling down until you find a color you like.
    I use Scope 1. I find it the best color for me.
    As for your mouse and tuning. I can you my mouse to move around the waterfall if that is what you want to do. Just put your mouse on the waterfall and move it around to the signal you want to copy.
    Hope this helps.
  3. N2LK
    Thanks for the advise.
    On the mouse wheel tuning, what I like with MixW is that you put the curser on the waterfall and with the mouse wheel, you can tune your radio up and down the band, not just move around in the waterfall display..
    Be nice to see if DM780 could do that...
    Thanks again...
  4. KE5MC
    different approach
    DM780 can tune the radio, but it is in 500 cycle increments. In the attachment look above the 14 in the upper left corner. The two double chevrons change the frequency up or down by 500.
  5. N5MDT
    N5MDT Premium Subscriber QRZ Page
    Adjust your RF Gain down some...
  6. WD0MYM
    WD0MYM Ham Member QRZ Page
    I could see that your audio percentage near the bottom of your DM780 shot was 1%. That is really really low. I tested it on mine and get very little printing at that level.
    Some of the settings I use are as follows:
    Go to Options--->Waterfall--->Colour--->
    Adjust the colour to Scope 1. I think this is the default.
    Go to Options--->Waterfall--->Frequency, Mode, Speed--->
    Under Mode, I have that set to Waterfall
    Waterfall Display Mode is set to "Log 10-90%"
    Smoothing with the slider in the middle. Play with that setting also.
    And one of the more important is the "Clipping". Try playing with this one. I run mine on about 50-60%. As a note, I run the audio percentage at the bottom of the DM780 screen at about 30-40%. It will print at a lot less percentage, but I think 1% is still too low.
    As you raise the clipping level, you'll see less noise and just the signal traces on a black background.
    WD0MYM
    Jon
