Diawa CN720B variable resistor replacement
Discussion in 'Radio Circuits, Repair & Performance' started by W3KKO, May 13, 2019.
  1. W3KKO
    W3KKO XML Subscriber QRZ Page
    I picked up a Diawa CN720B meter is great condition....short of the readings are intermittent. Upon careful opening and inspection, a preset variable resistor (100K ohm, 2-pin, unknown other specs and manufacturer) legs is broken through just above where it looks to crimp/solder. I am having a devil of a time finding this resistor online, other than the random photo on a guitar amp blog. If I could find an adequate replacement resistor, I'd likely take it to a good repair guy/girl to repair. Although, I can do a bit of soldering, so maybe repair myself. Thank you in advance for any guidance you can give. 73 W3KKO
  2. W3KKO
    And I realized its Daiwa.......please forgive my spellin' :)
  3. K5DH
    K5DH Ham Member QRZ Page
    Please post a photo of the part. Sounds from your description like a fairly typical trimmer pot, but a photo would go a long way.
  4. W3KKO
    Trying to upload a photo
  5. W3KKO
    The resistor with broken tab is the half hidden one on the right. 100K is stamped on it, which matches the schematic. Almost looks like they are all crimped into tabs soldered onto the board.
  6. KP4SX
    KP4SX XML Subscriber QRZ Page
    Its a standard trimpot. Apparently they used eyelets for the thru-plated holes on the board.
  7. W3KKO
    Thank you Bill. I'm a bit unsure of what spec beyond 100K ohms, such as power handling, I need to purchase. Highest is best, correct? I also see mostly 3 pin versions. I believe I can connect the center pin to an outer pin and go from there. Guidance is appreciated.
