Hi all, I just bought a new-to-me Dodge truck and I’m planning out my radio installation. I’m planning on purchasing a Yaesu FT-8900R and mounting a CR-8900 antenna on the rear of the toolbox in the bed. I’ll get some aluminum angle to make a bracket, bolt it to the back of the box, run a ground wire from the box to the bed and the frame, etc. Any thoughts on this antenna placement?
I did that on my first install, on an old Dakota. When you say "back", do you mean the rear most edge of the box? I initially installed the antenna on the front surface of my tool box, and the whip was too close to the truck cab to get a consistent SWR. When I moved the mount to the side, it got better. On my current install, it's on the bed itself: https://forums.qrz.com/index.php?threads/mobile-install-2007-dodge-ram-pics.639412/ If you're going to use the tool box, make sure it has both DC and RF grounds.
From front to back, VSWR 1.2:1 VHF/1.3:1 UHF, 1.1:1, and 1.1:1. The method has never failed me. Though I see the weight and wind load issues of the 8900 make roof top mounting questionable without reinforcing the mouting area. I've used AC cover plates and other metal panels to acomplish that in various installations.
