DDS VFO
Discussion in 'Homebrew and Kit Projects' started by KC4DYM, Sep 4, 2011.
  1. KC4DYM
    KC4DYM Ham Member QRZ Page
    Bought a AD9851 moduel off ebay want to use in the dds any good ideas ? Or sites ?
    thanks & 73
    Ray
    KC4DYM
  2. W9GB
    I would have probably just bought one of the many DDS kits with all the parts (and LCD) !
    eBay seller: kuuco in Guang Zhou, China, provides a schematic diagram with his AD9851 sales
    Analog Devices AD9851: 180 MHz Complete DDS synthesizer - datasheet
    http://www.analog.com/en/rfif-components/direct-digital-synthesis-dds/ad9851/products/product.html
    George Heron's DDS-60 kit / daughterboard
    http://midnightdesignsolutions.com/dds60/index.html
    DDS VFO version 4.0 by CV Niras, VU3CNS
    http://www.hamradioindia.org/circuits/dds.php
    Experimenting with the Analog Devices AD9851 DDS by OH2NLT
    http://www.nikkemedia.fi/hohtola/dc-trcvr/AD9851/ad9851.htm
    AD9851 Mini-kits (Australia)
    http://www.minikits.com.au/kits5.html
    Tech Talk 13 on AD9851 DDS VFO by Jan Skirrow (October 2005)
    http://skirrow.org/Boatanchors/TechTalk13.pdf
    w9gb
  3. KL7AJ
    Does that have both in-phase and quadrature outputs? If so, you can make a killer coherent receiver.
    Eric
  4. WD5HHH
    WD5HHH Ham Member QRZ Page
    Quadrature Output
    KL7AJ,
    That requires the AD9854 to get quadrature from one device. Otherwise you must have two DDS chips. You then program one to be 90 degrees lagging phase with respect to the other chip. Most of the Analog Devices DDS chips have this capability. I have been doing some study on this. Want to build a nice super, DDS based VFO but other factors in my life are minimizing my Ham Radio activities.
    Bill
  5. AB9LZ
    AB9LZ Ham Member QRZ Page
    If you haven't selected a micro for controlling the thing, Id recommend the PIC, just as easy to program as the audrino, with a *lot* less fru fru. The pickit2 actually comes with some C based sample source code thats a perfect starting point for your custom vfo. If you aren't setup to etch a board, I'd recommend a kit, the narrow profile ad9851 leads are too fine to solder dead big style.
    73 m/4
  6. WA6TLP
    WA6TLP Ham Member QRZ Page
    I bought a kit from N3ZI, installed it in my recently restored homebrewed rig and I can truthfully say that it has solved a major problem I had with the rig for 30 years. The kit came complete with everything including a large display and all the parts. My only complaint is (to keep the cost down) a mechanical encoder was included. The encoder has some annoying 'bounce' to it and I will probably replace it with an expensive optical encoder eventually.
    Notice the digital readout where the dial once was.
  7. AB9LZ
    Check to make sure the software will support an optical encoder before sticking one in there, a) there could be slight programming differences between the two, especially if the pulse detection is done with interrupts. b) with higher resolution encoders, the pulses come much faster, and there is no guarantee of the start state (see point a) ).
    73 m/4
  8. WA6TLP
    You are right, the unit does need a slight programming change to accommodate an optical encoder, however it has an RS232 interface built into the board and all you have to do is change a couple of parameters in their registers by linking to your PC. I have a USB to RS232 adapter, so that shouldn't be a problem. Evidently, the the debounce algorithm has to be disabled when using an optical encoder.
    Have the radio on tonight and have already had a couple of skips. Probably won't be too long before I replace the encoder. Still, this is such an amazing improvement over the 12AX7 Colpitts oscillator I originally built for the rig.
  9. K5UOS
    K5UOS Ham Member QRZ Page
    WA6TLP,
    Awesome rig! I enjoyed the history and the write up linked in your QRZ bio. John, you definitely have the knack!
    73, K5UOS
  10. WA6TLP
    Ha, ha. Thanks very much Don.
    Read your bio page and man oh man, you are guy after my own heart -- tubes and all. I used a triode/pentode for a receiver mixer just to avoid the noise you mentioned, but really didn't notice it was any quieter than a pentagrid such as you used. Sure would like to QSO with you sometime, but it appears you are a CW man and I'm not. I nearly scrubbed out of Radioman 'A' school because I just couldn't pass the 16WPM code requirement. Finally squeaked by after sweating bullets, then the next year they dropped the code altogether. Just barely got my general/advanced because of the code. Always had a disconnect in my brain for sound patterns, most likely.
    Perhaps you are a more careful worker and are able to build robust and drift free VFO's but all my attempts were failures and my rig would drift especially while transmitting when the final would cause the chassis to heat up. If you are having any problem with drift and/or you want to bring your rig up to date with a digital readout, I highly recommend using some kind of DDS like mine, but don't mess around with a mechanical encoder, go for a optical one for more money.
    73's.
