Dc volts on aerial socket
Discussion in 'General Technical Questions and Answers' started by G4REK, Apr 6, 2012.
  1. G4REK
    G4REK Ham Member QRZ Page
    Hi,
    Ft897d which i thought i would connect to my Clansman atu tuning unit...all works fine ..but on switching off the radio the meter on the atu
    (which will only respond with a clansman radio 320 or 321 radio) flicks hard over full scale for a second same on switching set on.....
    with the clansman radios connected they send a dc voltage to the meter circuit so that it reads power out/tuning.....
    but why is there a dc voltage on the 897d aerial socket when it being switched off/on ???????and it must be a fair voltage to give a hard over with the needle.....sorry bit long winded but it puzzles me somewhat
    thanks Jim g4rek
    9
  2. N0SYA
    N0SYA Ham Member QRZ Page
    I wonder if some cap in the yazoo is discharging via the socket on shutrdown?
  3. G4REK
    Hi
    Do not know but it does it on switch on as well......think i will put my ft 847 in its place and see what happens on switch on /switch off.....
    do not like the way the meter slams over full scale for a second........
    Jim...........
  4. AB9LZ
    AB9LZ Ham Member QRZ Page
    A lot of rigs will put a DC "wetting current" on the tr relays to keep the contacts clean, two of my rigs do it, however, there is usually a blocking cap in there some where. Check the schematic.
    73 m/4
  5. G4REK
    Have put my FT847 in line and there is not any needle kick at all now........be interesting if a ft897d owner could put dc volt meter across the hf socket and see if there is a brief needle movement on switch/switch off ,,,to be safe rf control at minimum setting and radio set to 7 megs band........ Jim g4rek
  6. N5USR
    N5USR Ham Member QRZ Page
    My assumption would be it's something to do with the ATAS-120 tuning circuit. When tuning it will put certain DC voltages on the antenna jack to control the ATAS. Of course I don't know why it would do so at power on/off...
    I have an 857D, same guts as the 897D, and mine does very briefly blip a multimeter when I turn it on/off. It's hard to get an accurate reading as the voltage is very brief and my digital meter doesn't register quickly enough. Most times it's only a few millivolts but on occasion I see 2-3V.
  7. G4REK
    Right thanks that sounds as though your is behaving same as mine, as you say its so brief difficult to get a reading.......would not have normally noticed it but connected to the Clansman atu it kicks the meter hard across very briefly
    thanks for you help
    regards Jim
ad: TiltPlate-1
