DC High Voltage Breakdown Rating Of
Discussion in 'General Technical Questions and Answers' started by N0PGR, Sep 28, 2010.
  1. N0PGR
    N0PGR Ham Member QRZ Page
    Well for me I'm looking for is....
    How much DC Voltage can pass through
    PL-259 and SO-239 and BNC , F , N......
    and so on
    As far as Coax Cable
    I have seen numbers applied to
    RG-58 of 1900VRMS
    RG-59 of 2300VRMS
    RG-8[PE] of 4000VRMS
    RG-213 of 5000VRMS
    and if you could imagine
    RG-6 of 2700VRMS
    Good and plenty I say
    .......But.......
    Wouldn't VRMS imply a AC Voltage
    What about DC High Voltage
    I have seen opinions for
    DC breakdown Voltages of
    RG-58 @ 10KVDC
    RG-59 @ 30KVDC
    RG-213 @ 50KVDC
    So what is the actual DC rating
    Anyone
    So why all this business
    :confused:
    I'm building a large multi band V/UHF amplifier
    Using multi PA decks
    With one LARGE HV Power Supply
    I need to get 1800 to 2300 Volts of B+ to all the decks
    { safely ;) }
    Besides, haven't you had a thought on this
    subject before at one time or another
    Thank you
    Terry N0PGR
    73​
    For detached amplifiers/power supplies I use high voltage wire, not coax. HV test probe cable is easy to find rated at 5kV DC, and much higher if you wish. Some of the silicone rubber insulated stuff is good for 20 kV+ and it's cheaper and more flexible than coax.
    For B+ I use either Millen 7kV connectors (very commonly found and available, and cheap) or MHV connectors.
    I wouldn't use type UHF or BNC or N, as those can be too easily confused for antenna connections.
    My grounds and B- returns are separate: A couple of paralleled ground wires run in the multi-pin connectors that are used for LV, filaments, switched AC, metering and other stuff; plus the third prong in the AC power cord provides a solid utility service return. I usually bring B- out separately from "ground," as it floats slightly above ground (not much, usually floated by the plate current meter shunt resistor and a fault diode) so I can meter plate current in the B- return path.
    The DC voltage rating for cables should always be somewhat higher than the AC RMS voltage rating, by at least a factor of 1.414. I just avoid using coax for B+ because it's too easily confused for antenna wiring, especially if a guest operator has to de-bug something when I'm not around.
  3. N0PGR
    Cheap is the is the key
    Noted 7mm solid core spark plug wire can be used also
    Have coax
    Poked out there on the net for these
    Millens about $10 each
    MHV about $10 each
    Thats getting up there
    $100 for B+/B- connections
    and that is w/o wire
    Nice , sure is......
    Have PL-259/SO-239 just in the drawer
    Thought about mixing up the connectors
    Got to be a work around for that
    So if one were to use the 2300VRMS you should be covered then
    For this thing RG-213 type will be used
    Flexibility , not an issue
    Terry N0PGR
    Besides, kind of like the idea of
    ground shielded B lines
    Say if one got nicked or cut
    Keeps it inside cable​
  4. N0PGR
    I found something rather interesting ​
    http://www.timefracture.org/reg.html
    {holy fix oversized pictures}
    Answered my own question finally
    And Thanks to John Doran KV0L
    Terry N0PGR
    73​
  5. KB4QAA
  6. KE3WD
    KE3WD Ham Member QRZ Page
    Using the same connectors for the deadly high tension lines as you do for your Antenna and input connections is a recipe for disaster.
    Don't think that you would never make a mistake sometime.
    "Never say 'never'"...
  7. W5RB
    W5RB Guest
    What's with the bizarre format ? It's like you're using a template for a wall poster of the Desiderata , and it's ..... distracting .
  8. AG3Y
    AG3Y Guest
    If I remember my math properly, you take the RMS values you have listed above, and multiply by 1.414. That will give you the peak of the AC voltage, which should be the same as the maximum DC voltage that the cable is rated for !
    WD has good advice. Use special HV cable rather than coax. A life is PRICELESS ! ! !
  9. K7NI
    K7NI Ham Member QRZ Page
    I have seen modified coax connectors like the ones pictured used on a Hi-Pot tester.
    Regular PL-259, SO-239 and BNC connectors are rated for 500 Vpeak. N connectors are rated for 1500 Vpeak
  10. K8ERV
    K8ERV Ham Member QRZ Page
    I think there are too many variables to come up with one figure. Instantaneous breakdown? Long term breakdown? How clean are the surfaces, etc.
    I worked in a lab that applied 50kv (briefly) to RG-8 in a pulse generator.
    TOM K8ERV Montrose Colo
ad: M2Ant-1
