D104 to Kenwood TS2000
Discussion in 'Microphones, Speakers & Audio Processing' started by K3AXR, Apr 21, 2012.
  1. K3AXR
    K3AXR XML Subscriber QRZ Page
    I just purchased ana Astatic D104 microphone for old times sake. I have a Kenwood TS2000 and need to not only adapt the connectore but match the impedance. The data I found on says I need to build an Active Buffer-Amplifier. Does anyone offer this as an already built unit? I'm basically lazy and if I can but this as well as the needed changes from the 4-pin mic connector on the mic to an 8-pin for the TS2000. Any thoughts on this will be greatfully appreciated.
    de K3AXR
    Dell Palmer
    k3axr@arrl.net
  2. KD8DEY
    KD8DEY Ham Member QRZ Page
    On the bottom of the D-104 is there a small hole with an adjustment inside??
  3. W0LPQ
    W0LPQ Ham Member QRZ Page
  4. W9GB
    Dell -
    Great, but Astatic built the D-104 over a 70 year period -- SO you need to determine the BASE
    that your purchase has. THIS will determine the options and choices for matching impedances to
    your Kenwood TS-2000 transceiver.
    D-104 Schematics of various base stands.
    http://www.barovelli.com/projects/radio/radioastatic.htm
    The "G" and "UG8" stands do not have a pre-amplifier or impedance matching transformer.
    In those instances, the crystal microphone element (Hi-Z, 25K - 50Kohms Z) would need to be matched to
    the lower impedance (~600 ohms Z) microphone input of your Kenwood TS-2000.
    w9gb
    My D-104 Preamplifier - Tone Control
    Alan Wolke, W2AEW (1999)
    http://www.qsl.net/w2aew/myd104amp.html
  5. K3AXR
    Yes, there is a small hole with a cream colored adjustment under it.
  6. KD8DEY
    Then it's an amplified version. you don't need to worry about a buffer.
    the amp serves that purpose And the impedance should be fine.
    BUT you need to figure out which version you have.
    does it only have 4 wire and a small switch underneath the plate
    or does it have more than four wires in the mic cord and no switch (shield white black red blue yellow)
  7. K3AXR
    The mic cord has 4 wires; shield, black, red and white.
  8. KD8DEY
    put the switch to R for Relay switching
    Pin 1 White
    Pin 2 RED
    Pin 7 Shield
    Pin 8 Black
  9. KB4QAA
    Once again, may I suggest we have a sticky just for D104 mics to answer these perpetually repeating questions? :)
  10. K3AXR
    Thanks for the help,KD8KDY.
    Dell
