ad: Schulman-1
Conductive Copper foil Tape for Antenna?
Discussion in 'Antennas, Feedlines, Towers & Rotors' started by K2POP, Aug 24, 2011.
  1. K2POP
    K2POP Ham Member QRZ Page
    Has anyone made an antenna using conductive copper foil tape? If so, please tell me about it. How different is copper tape from copper wire? :confused:
    Thanks, Richard
    Wire is stronger.;)
    Copper foil tape is handy if it's adhesive backed and you're sticking it to a window or something. It might even be handy (if adhesive backed) for "winding" a helical radiator on a shaft.
    But it's usually pretty thin, so I wouldn't use it for anything self-supporting.
    As a "conductor" for an antenna, it should be fine. The issue is mostly mechanical strength.
  3. NH7RO
    NH7RO Ham Member QRZ Page
    I always thought about trying to make a copper-tape yagi with fishing poles for a lightweight beam good for portable stuff.... Wonder if anyone else has actually done so?
  4. WB2WIK
    There was a QST article years ago for exactly this, and I did build it.
    It's okay, but frankly aluminum tubing is every bit as lightweight and if you use telescoping sections even a 20m beam can be collapsed to fit in the trunk of a car, and it's less finnicky. You can build a 20m beam from thinwall aluminum tubing that weighs 5 lbs for portable work. It may not survive an ice storm, but I wouldn't expect it to.:eek:
  5. N0AZZ
    N0AZZ Premium Subscriber QRZ Page
    Several years ago my club had a project where new Tech's made a copper tape 2m antenna on plexiglass that folded up for there go bag at the folds wire was bonded to the tape. They worked well next was a copper J pole project.
